SeaWolfX
- Mar 14, 2018
I am setting up a MySQL/MariaDB instance on my server using Docker and the data will be stored on a ZFS pool.
Several guides/blogs mentions that its best practice to separate data and log files to separate datasets with different properties. So in my docker-compose I create two volumes for mapping a data- and log directory under /var/lib/mysql.
(normally, when not using ZFS I would have just mapped the whole /var/lib/mysql directory to a single volume)
I also map to a configuration override file which adds the following to the my.cnf so that logs and data are stored in different directories and not directly under /var/lib/mysql which is the default.
When I create the container and navigate to the /var/lib/mysql directory (inside the container) I see that the data/ and and log/ directory has been created and contains data and log-files.
However, there are still some additional files and folders (I guess one for each database, they only contain a db.opt file) in the /var/lib/mysql directory. I assume that these are file that also need to be persisted (as typical practice is to persist the whole mysql directory) so that they are not lost if recreating the container for instance. Do I need to create a third volume that maps to the root directory or are these files/folders not important to persist?
Is this the correct approach for separating logs and data files when using MySQL/MariaDB Docker image?
- type: volume
source: cloud-database-data
target: /var/lib/mysql/data
- type: volume
source: cloud-database-logs
target: /var/lib/mysql/log(normally, when not using ZFS I would have just mapped the whole /var/lib/mysql directory to a single volume)
[mysqld] datadir = /var/lib/mysql/data innodb_log_group_home_dir = /var/lib/mysql/log innodb_data_home_dir = /var/lib/mysql/data slow_query_log_file = /var/lib/mysql/log/slow.log log_error = /var/lib/mysql/log/error.log aria-log-dir-path = /var/lib/mysql/log
drwxr-xr-x 7 mysql mysql 9 Apr 18 08:03 ./ drwxr-xr-x 8 root root 8 Apr 6 00:10 ../ drwxr-xr-x 2 mysql mysql 5 Apr 18 08:03 data/ drwxr-xr-x 2 mysql mysql 6 Apr 18 08:03 log/ -rw-rw---- 1 mysql mysql 0 Apr 18 08:03 multi-master.info drwx------ 2 mysql mysql 90 Apr 18 08:03 mysql/ -rw-r--r-- 1 mysql mysql 15 Apr 18 08:03 mysql_upgrade_info drwx------ 2 mysql mysql 3 Apr 18 08:03 nextcloud/ drwx------ 2 mysql mysql 3 Apr 18 08:03 performance_schema/
