I've been struggling for a while to get nextcloud working correctly in a container running on a ubuntu server VM. I'm trying use Wonderfall's nextcloud container and a mariadb container.
Basically, I have an NFS mounted in the VM to /media/containers/nextcloud. When I `ls` on both, the userids are different:
Freenas
Ubuntu Server VM on Freenas
This is the same for other mounts for containers, such as Pi-Hole and Portainer so I guess it's not an issue. But when I try to run the following, I get an error from docker:
When I run 'docker logs nextcloud_db', I see the following error:
I tried all combinations of mapall/maproot/etc but currently have mapall and mapgroup set to the 'docker' user/group (1000).
Has anyone else gotten this working? I feel like I'm missing something obvious or maybe there's a better way to mount directories in the containers.
[EDIT] Just a note, the user id of the docker user/group on the freenas is 1000, as is the local user of the vm:
Freenas
Freenas
|--$ ls -lh /mnt/tank/containers/nextcloud/ total 14 drwxrwxrwx 2 docker docker 2B Jun 8 14:48 apps drwxrwxrwx 2 docker docker 3B Jun 8 15:30 config drwxrwxrwx 3 docker docker 6B Jun 8 15:30 data drwxrwxrwx 2 docker docker 2B Jun 9 16:21 db drwxrwxrwx 2 docker docker 2B Jun 8 14:48 themes
ls -lh /media/containers/nextcloud/ total 14K drwxrwxrwx 2 nobody 4294967294 2 Jun 8 14:48 apps drwxrwxrwx 2 nobody 4294967294 3 Jun 8 15:30 config drwxrwxrwx 3 nobody 4294967294 6 Jun 8 15:30 data drwxrwxrwx 2 nobody 4294967294 2 Jun 9 16:21 db drwxrwxrwx 2 nobody 4294967294 2 Jun 8 14:48 themes
docker run -d --name nextcloud_db -v /media/containers/nextcloud/db:/var/lib/mysql -e MYSQL_ROOT_PASSWORD=supersecretpassword -e MYSQL_DATABASE=nextcloud -e MYSQL_USER=nextcloud -e MYSQL_PASSWORD=supersecretpassword mariadb:10When I run 'docker logs nextcloud_db', I see the following error:
docker logs nextcloud_db chown: changing ownership of '/var/lib/mysql/': Invalid argument
Freenas
|--$ grep docker /etc/passwd docker:*:1000:65534:Docker User:/nonexistent:/usr/local/bin/bash |--$ grep docker /etc/group docker:*:1000:
$ id uid=1000(<user>) gid=1000(<user>)
