samliddicott
- Apr 26, 2021
I'm trying out TrueNAS on a QNAP, which has some kind of solid-state DOM (500MB) to boot from.
Solid state and the small size rule it out as a boot/system device.
So I installed on an external USB disk, but every bootup the initramfs fails with:
great gratitudes to whoever caused that verbose message, because it works, and I type:
and it boots fine.
Is the error because the disk was USB based and USB starts up later?
But next, can't we have the system stored on one of the main disks and only need to have the EFI folder on a separate device (to fit on my DOM).
Why does the zfs_member on the boot device need to be stored there and not on one of the other disks?
AFAICT I could shift about the partitions on my first disk and move it there and it would still work, and then move the EFI partition to my DOM
Failure: 1 Command: /sbin/zpool import -N 'boot-pool' Message: cannot import 'boot-pool': no such pool available Error: 1 Failed to import pool 'boot-pool'. Manually import the pool and exit.
/sbin/zpool import -N boot-pool exit
and it boots fine.
