I have a primary NAS with 4x6TB in RAIDZ2 and just got a second for backup with the same configuration. On both machines, the system dataset is on the main pool. When starting the replication, FreeNAS objected to the system dataset being on the replication target pool. This seemed to make sense as it would be overwritten, so I moved the dataset to the freenas-boot pool which is a USB stick and therefore sub-optimal to hold the system dataset.
I am considering adding a 2GB (or whatever) slice on each drive and creating an additional pool across these to hold the system dataset.
Will this work? Is it sensible? Is it worth the hassle? If it was sensible, I would assume the FreeNAS installer would offer to create a small pool for the dataset if all storage was going to be allocated to a single pool.
