Separate Shares with TrueNAS
EastPipe82
Hi all :smile:
I'm using an TrueNAS system with two storage pools: the first is a bond of 6 HDDs (RAID5), and should be only available "offline" within our house ("classic" NAS storage). The second one is a bond of 2 HDDs (RAID1). This pool should be used as a private "cloud" (available via the internet). As my machine supports two physical ethernet ports, I want the "private pool" to be accessible via the first port, and the "cloud pool" via the second one. Additionally it would be great, to redirect the private cloud to a proxy.
Can anybody help me, configuring this scenario?
(sorry for my poor english...)
I'm not convinced that physically separate NICs is the "magic firewall" solution that you're actually seeking.
I would expect that you would be able to use a local sharing protocol like SMB to cover the local needs and an application like Nextcloud (with a reverse proxy) to cover the external one.
If it makes you somehow feel "safer" to have your nextcloud jail running on a different NIC than your SMB traffic (like I said, not actually making it any safer), then there are plenty of guides in the forum for having jails connect to a specific NIC.
Chris Moore
