Archaeopteryx
- May 9, 2014
first, let me thank you for your knowledge base (especially thanks to cyberjock) with helpful tips and tutorials to configure FreeNAS. At the moment everything runs (nearly;)) smoothly.
I built my system after various recommendations (certainly with ECC:D) and tested it now like a month with only a single HDD (1.5 TB):
My system:
Intel Xeon E3-1230 v3, 4x 3.30GHz
2x Kingston ValueRAM DIMM 8GB, DDR3-1333, CL9, ECC
Supermicro X10SLM+-F bulk
Fractal Design Define Mini
be quiet! Straight Power E9 400W
Everything works fine. Only the space is already full ;)
So my buying list is at the moment:
4 x HGST Deskstar NAS 4TB 7200rpm, SATA 6Gb/s (a 137,75€) (continuous operation ready)
My first intention was to use it as RAID-Z2 (RAID6), because I read an article that RAID-Z1 isn't sufficient for HDD > 3TB (long rebuild times etc)
But with Raid-Z2 I could only use 8TB from the 16 TB :/
To get more space, I want to split my Data. One big chunk is data1, which could easily restored from other sources(Like movie trailers etc.). So if data1 would go bankrupt, it wouldn't be a problem. The other chunk are backups, my personal picture library and personal video files which shouldn't go bad.
I would make two pools(?), the first is a RAID-0 or JBOD configuration, the second one would be a simple mirror. (To have a normal backup for the private stuff).
I would now have for data1 4TB+4TB=8 TB
and for the private data (4TB+4TB)/2 = 4 TB
accessible. So 4 TB more than the RAID-Z2 configuration.
(Additionally I have an extern 4TB drive as a backup for the private data.)
Now to my questions:
1) If I want to add after some time 2 6TB drives to the “pool” data1, would it be possible?
2) Could I eject one HDD (from data1) of the server and (without maybe one file at the border) access the data in an extern USB case? (Because Wikipedia shows that the data in JBOD is written sequentially)
2) Is the configuration above okay or would you want to warn me about it?
3) Is the mentioned HGST HDD okay? I would, as an alternative, choose the WD RED, but the HGST is a little bit faster.
Thank you very much,
Archaeopteryx
Ps: I hope you can understand my English text. I haven't written english for quite a long time. Feel free to correct me :)
My system:
Archaeopteryx
