When I click the Apps tab I'm prompted to 'Choose a pool for Apps'
After I select my pool and click Choose
The following appears for about 20 seconds (no change to the percentage)
Configuring
kubernetes.update 0.00%
Fetching data
Then I get the error: Error: [EFAULT] Missing 'cpu, cpuset, hugetlb' cgroup controller(s) which are required for apps to function
and get returned back to the choosing a pool, if I try to select the pool again I then get the error: Error: [EINVAL] kubernetes_update.force: Missing '/mnt/zpool0/ix-applications/config.json' configuration file. Specify force to override this and let system re-initialize applications.
Configuring
Fetching data
