NightNetworks
- Sep 6, 2015
FreeNAS.local changes in mounted filesystems:
10c10,11
< ESXi/VMs /mnt/ESXi/VMs zfs rw,nfsv4acls 0 0
> Extra /mnt/Extra zfs rw,nfsv4acls 0 0
> Extra/Extra /mnt/Extra/Extra zfs rw,nfsv4acls 0 0
FreeNAS.local kernel log messages:
> ugen1.3: <vendor 0x0000> at usbus1
> uhub4: <vendor 0x0000 product 0x0001, class 9/0, rev 2.00/0.00, addr 3> on usbus1
> ugen1.4: <vendor 0x0557> at usbus1
> ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus1
> ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus1
> ugen1.5: <vendor 0x13fe> at usbus1
> umass0: <vendor 0x13fe Patriot Memory, class 0/0, rev 2.10/1.00, addr 5> on usbus1
> umass0: SCSI over Bulk-Only; quirks = 0x8100
> umass0:7:0:-1: Attached to scbus7
> Timecounter "TSC-low" frequency 1400030856 Hz quality 1000
> vboxdrv: fAsync=0 offMin=0x2c0 offMax=0xf94
> WARNING: 192.168.2.1 (iqn.1998-01.com.vmware:esxi-1d4dad82): no ping reply (NOP-Out) after 5 seconds; dropping connection
> pid 2130 (syslog-ng), uid 0: exited on signal 6 (core dumped)
> GEOM_ELI: Device ada5p1.eli destroyed.
> GEOM_ELI: Detached ada5p1.eli on last close.
> GEOM_ELI: Device ada4p1.eli destroyed.
> GEOM_ELI: Detached ada4p1.eli on last close.
> GEOM_ELI: Device ada0p1.eli created.
> GEOM_ELI: Encryption: AES-XTS 256
> GEOM_ELI: Crypto: software
-- End of security output --
As the thread suggests I am new to FreeNAS and thought that I would post the Security Run Output e-mail that I got last night to see if there are any issues...
The only two things that I see that may be an issue is the warning regarding the "no ping reply" and the "tsc-low frequency". I think that I know what the "no ping reply" issue is and will look into that, but as far as the "tsc-low frequency" the forums suggested that is an issue with the clock? I am not seeing any issues with the clock?
Thanks in advance!
10c10,11
Thanks in advance!
