blueether
 - Aug 6, 2018
Hi all
I picked up a pair of old IBM x3659 m3 servers for around $100 (NZ) each to replace the desktop that has been running freenas for about a year now.
specs:
cpu: x2 5620
mem: 48 and 96 GB ecc ddr3
raid: m1015 (now flashed to IT)
lsi 9212-4i4e x2 in each
extra intel dual gigabit NIC in each plus the dual onboard gigabit NIC
One has 4 136 GB sas drives in and the other has 8 600 GB sas drives. I'm not too worried about the 136 drives but I'd like to use the 600's as a backup (I plan to use the lower spec one as a backup). There will be new sata drives that will go in the other one.
Are these drives ok to use?
specs:
cpu: x2 5620
root@IMB-FreeNAS[~]# zpool status -v SAS_600_Z2
  pool: SAS_600_Z2
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:01 with 0 errors on Sat Jun 22 19:36:56 2019
        SAS_600_Z2                                      ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/7e35d9af-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/8b81303d-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/98a6c5fc-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/a6c79d04-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/b4821bbd-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/c2726f5e-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/d0dc8260-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
            gptid/de653557-94b9-11e9-b068-000c29405c32  ONLINE       0     0     0
errors: No known data errors
root@IMB-FreeNAS[~]# smartctl -a /dev/da1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:               IBM-ESXS
Product:              ST600MM0006
Revision:             B56T
Compliance:           SPC-4
User Capacity:        600,127,266,816 bytes [600 GB]
Logical block size:   512 bytes
Formatted with type 2 protection
LU is fully provisioned
Rotation Rate:        10500 rpm
Form Factor:          2.5 inches
Logical Unit id:      0x5000c50074198a0f
Serial number:        S0M56EQK0000K53968EC
Device type:          disk
Transport protocol:   SAS (SPL-3)
Local Time is:        Sat Jun 22 20:03:55 2019 NZST
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
SMART Health Status: OK
Current Drive Temperature:     37 C
Drive Trip Temperature:        65 C
Elements in grown defect list: 0
Vendor (Seagate) cache information
  Blocks sent to initiator = 0
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 7074.73
  number of minutes until next internal SMART test = 1
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:   1325118345        0         0  1325118345          0     116183.297           0
write:         0        0         0         0          1      15523.521           0
verify: 1152572776        0         0  1152572776          0       6886.947           0
Non-medium error count:      139
SMART Self-test log
Num  Test              Status                 segment  LifeTime  LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
# 1  Background short  Completed                   -    7073                 - [-   -    -]
Long (extended) Self Test duration: 3777 seconds [63.0 minutes]
root@IMB-FreeNAS[~]# smartctl -a /dev/da2
Vendor:               IBM-ESXS
Revision:             B56T
Compliance:           SPC-4
Logical Unit id:      0x5000c50074250b87
Serial number:        S0M0Y6F40000M407225M
Device type:          disk
Local Time is:        Sat Jun 22 20:03:59 2019 NZST
Current Drive Temperature:     39 C
  number of hours powered up = 7051.77
Error counter log:
read:   3157756852        0         0  3157756852          0       1453.591           0
write:         0        0         0         0          1       5674.616           0
verify: 1059087137        0         0  1059087137          0        523.097           0
Non-medium error count:       37
No self-tests have been logged
Vendor:               IBM-ESXS
Revision:             B56T
Compliance:           SPC-4
Device type:          disk
Local Time is:        Sat Jun 22 20:11:32 2019 NZST
  number of hours powered up = 7051.88
  number of minutes until next internal SMART test = 53
Error counter log:
write:         0        0         0         0          1       5674.663           0
verify: 1059087831        0         0  1059087831          0        523.097           0
root@IMB-FreeNAS[~]# smartctl -a /dev/da3
Vendor:               IBM-ESXS
Revision:             B56T
Compliance:           SPC-4
Logical Unit id:      0x5000c50074261d0b
Serial number:        S0M3NXYR0000M512EUQA
Device type:          disk
Local Time is:        Sat Jun 22 20:11:40 2019 NZST
  number of hours powered up = 7051.85
Error counter log:
read:   2576738356        0         0  2576738356          0     115317.416           0
write:         0        0         0         0          2      14863.446           0
verify: 1985559945        0         0  1985559945          0       6711.879           0
Non-medium error count:       99
root@IMB-FreeNAS[~]# smartctl -a /dev/da4
Vendor:               IBM-ESXS
Product:              MBF2600RC
Revision:             SB27
Compliance:           SPC-4
Rotation Rate:        10025 rpm
Logical Unit id:      0x50000393a8204108
Serial number:        EA09PBB0G7M2
Device type:          disk
Local Time is:        Sat Jun 22 20:11:52 2019 NZST
Current Drive Temperature:     40 C
Manufactured in week 46 of year 2011
Specified cycle count over device lifetime:  50000
Accumulated start-stop cycles:  46
Specified load-unload count over device lifetime:  200000
Accumulated load-unload cycles:  0
Error counter log:
read:          0        0         0         0          0    1113244.190           0
write:         0        0         0         0          0       7329.258           0
verify:        0        0         0         0          0        608.213           0
Non-medium error count:       96
SMART Self-test log
# 1  Background short  Completed                   -       1                 - [-   -    -]
Long (extended) Self Test duration: 5358 seconds [89.3 minutes]
root@IMB-FreeNAS[~]# smartctl -a /dev/da45
/dev/da45: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
root@IMB-FreeNAS[~]# smartctl -a /dev/da5
Vendor:               IBM-ESXS
Product:              HUC109060CSS60
Revision:             J2EE
Compliance:           SPC-4
Rotation Rate:        10000 rpm
Logical Unit id:      0x5000cca043a40844
Serial number:        KSJX6KRJ
Device type:          disk
Local Time is:        Sat Jun 22 20:12:09 2019 NZST
Current Drive Temperature:     38 C
Manufactured in week 04 of year 2014
Specified load-unload count over device lifetime:  600000
Accumulated load-unload cycles:  947
  Blocks sent to initiator = 12061414973767680
Error counter log:
read:          0        0         0         0   55771565      66441.354           0
write:         0        0         0         0     240803      26394.369           0
verify:        0        0         0         0     143826      18514.201           0
Non-medium error count:        0
SMART Self-test log
# 1  Background short  Completed                   -       0                 - [-   -    -]
Long (extended) Self Test duration: 4882 seconds [81.4 minutes]
root@IMB-FreeNAS[~]# smartctl -a /dev/da6
Vendor:               IBM-ESXS
Product:              MBF2600RC
Revision:             SB27
Compliance:           SPC-4
Logical Unit id:      0x50000393a81156ec
Serial number:        EA09PBB0F8R2
Device type:          disk
Local Time is:        Sat Jun 22 20:12:25 2019 NZST
Manufactured in week 45 of year 2011
Accumulated start-stop cycles:  44
Error counter log:
read:          0        1         0         0          0    1787062.553           0
write:         0        0         0         0          0      85374.912           0
verify:        0        0         0         0          0      35021.211           0
Non-medium error count:       97
SMART Self-test log
# 1  Background short  Completed                   -       3                 - [-   -    -]
root@IMB-FreeNAS[~]# smartctl -a /dev/da7
Vendor:               IBM-ESXS
Product:              MBF2600RC
Revision:             SB27
Compliance:           SPC-4
Logical Unit id:      0x50000393a82070b8
Serial number:        EA09PBB0G8P5
Device type:          disk
Local Time is:        Sat Jun 22 20:12:33 2019 NZST
Current Drive Temperature:     36 C
Accumulated start-stop cycles:  47
Error counter log:
read:          0        4         0         0          0    1792929.478           0
write:         0        1         0         0          0      87219.517           0
verify:        0        0         0         0          0      35020.846           0
Non-medium error count:       95
SMART Self-test log
root@IMB-FreeNAS[~]# smartctl -a /dev/da8
Vendor:               IBM-ESXS
Revision:             J2EE
Compliance:           SPC-4
Logical Unit id:      0x5000cca043a34234
Serial number:        KSJWTBUJ
Device type:          disk
Local Time is:        Sat Jun 22 20:12:54 2019 NZST
Current Drive Temperature:     32 C
Accumulated start-stop cycles:  5
Accumulated load-unload cycles:  948
  Blocks sent to initiator = 12060162621702144
Error counter log:
read:          0        0         0         0   55536193      66535.085           0
write:         0        0         0         0     277205      26396.090           0
verify:        0        0         0         0      80751      18514.205           0
SMART Self-test log
