blueether
- Aug 6, 2018
Hi all
I picked up a pair of old IBM x3659 m3 servers for around $100 (NZ) each to replace the desktop that has been running freenas for about a year now.
specs:
cpu: x2 5620
mem: 48 and 96 GB ecc ddr3
raid: m1015 (now flashed to IT)
lsi 9212-4i4e x2 in each
extra intel dual gigabit NIC in each plus the dual onboard gigabit NIC
One has 4 136 GB sas drives in and the other has 8 600 GB sas drives. I'm not too worried about the 136 drives but I'd like to use the 600's as a backup (I plan to use the lower spec one as a backup). There will be new sata drives that will go in the other one.
Are these drives ok to use?
specs:
cpu: x2 5620
root@IMB-FreeNAS[~]# zpool status -v SAS_600_Z2 pool: SAS_600_Z2 state: ONLINE scan: scrub repaired 0 in 0 days 00:00:01 with 0 errors on Sat Jun 22 19:36:56 2019 config: NAME STATE READ WRITE CKSUM SAS_600_Z2 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/7e35d9af-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/8b81303d-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/98a6c5fc-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/a6c79d04-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/b4821bbd-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/c2726f5e-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/d0dc8260-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 gptid/de653557-94b9-11e9-b068-000c29405c32 ONLINE 0 0 0 errors: No known data errors root@IMB-FreeNAS[~]# smartctl -a /dev/da1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: ST600MM0006 Revision: B56T Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10500 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c50074198a0f Serial number: S0M56EQK0000K53968EC Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:03:55 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 37 C Drive Trip Temperature: 65 C Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 0 Vendor (Seagate/Hitachi) factory information number of hours powered up = 7074.73 number of minutes until next internal SMART test = 1 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 1325118345 0 0 1325118345 0 116183.297 0 write: 0 0 0 0 1 15523.521 0 verify: 1152572776 0 0 1152572776 0 6886.947 0 Non-medium error count: 139 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 7073 - [- - -] Long (extended) Self Test duration: 3777 seconds [63.0 minutes] root@IMB-FreeNAS[~]# smartctl -a /dev/da2 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: ST600MM0006 Revision: B56T Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10500 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c50074250b87 Serial number: S0M0Y6F40000M407225M Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:03:59 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 39 C Drive Trip Temperature: 65 C Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 0 Vendor (Seagate/Hitachi) factory information number of hours powered up = 7051.77 number of minutes until next internal SMART test = 1 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 3157756852 0 0 3157756852 0 1453.591 0 write: 0 0 0 0 1 5674.616 0 verify: 1059087137 0 0 1059087137 0 523.097 0 Non-medium error count: 37 No self-tests have been logged root@IMB-FreeNAS[~]# smartctl -a /dev/da2 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: ST600MM0006 Revision: B56T Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10500 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c50074250b87 Serial number: S0M0Y6F40000M407225M Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:11:32 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 39 C Drive Trip Temperature: 65 C Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 0 Vendor (Seagate/Hitachi) factory information number of hours powered up = 7051.88 number of minutes until next internal SMART test = 53 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 3157756852 0 0 3157756852 0 1453.591 0 write: 0 0 0 0 1 5674.663 0 verify: 1059087831 0 0 1059087831 0 523.097 0 Non-medium error count: 37 No self-tests have been logged root@IMB-FreeNAS[~]# smartctl -a /dev/da3 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: ST600MM0006 Revision: B56T Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10500 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c50074261d0b Serial number: S0M3NXYR0000M512EUQA Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:11:40 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 39 C Drive Trip Temperature: 65 C Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 0 Vendor (Seagate/Hitachi) factory information number of hours powered up = 7051.85 number of minutes until next internal SMART test = 53 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 2576738356 0 0 2576738356 0 115317.416 0 write: 0 0 0 0 2 14863.446 0 verify: 1985559945 0 0 1985559945 0 6711.879 0 Non-medium error count: 99 No self-tests have been logged root@IMB-FreeNAS[~]# smartctl -a /dev/da4 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: MBF2600RC Revision: SB27 Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Rotation Rate: 10025 rpm Form Factor: 2.5 inches Logical Unit id: 0x50000393a8204108 Serial number: EA09PBB0G7M2 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:11:52 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 40 C Drive Trip Temperature: 65 C Manufactured in week 46 of year 2011 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 46 Specified load-unload count over device lifetime: 200000 Accumulated load-unload cycles: 0 Elements in grown defect list: 0 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 0 0 0 0 1113244.190 0 write: 0 0 0 0 0 7329.258 0 verify: 0 0 0 0 0 608.213 0 Non-medium error count: 96 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 1 - [- - -] Long (extended) Self Test duration: 5358 seconds [89.3 minutes] root@IMB-FreeNAS[~]# smartctl -a /dev/da45 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org /dev/da45: Unable to detect device type Please specify device type with the -d option. Use smartctl -h to get a usage summary root@IMB-FreeNAS[~]# smartctl -a /dev/da5 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: HUC109060CSS60 Revision: J2EE Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Formatted with type 2 protection Rotation Rate: 10000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000cca043a40844 Serial number: KSJX6KRJ Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:12:09 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 38 C Drive Trip Temperature: 65 C Manufactured in week 04 of year 2014 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 4 Specified load-unload count over device lifetime: 600000 Accumulated load-unload cycles: 947 Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 12061414973767680 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 0 0 0 55771565 66441.354 0 write: 0 0 0 0 240803 26394.369 0 verify: 0 0 0 0 143826 18514.201 0 Non-medium error count: 0 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 0 - [- - -] Long (extended) Self Test duration: 4882 seconds [81.4 minutes] root@IMB-FreeNAS[~]# smartctl -a /dev/da6 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: MBF2600RC Revision: SB27 Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Rotation Rate: 10025 rpm Form Factor: 2.5 inches Logical Unit id: 0x50000393a81156ec Serial number: EA09PBB0F8R2 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:12:25 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 39 C Drive Trip Temperature: 65 C Manufactured in week 45 of year 2011 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 44 Specified load-unload count over device lifetime: 200000 Accumulated load-unload cycles: 0 Elements in grown defect list: 0 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 1 0 0 0 1787062.553 0 write: 0 0 0 0 0 85374.912 0 verify: 0 0 0 0 0 35021.211 0 Non-medium error count: 97 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 3 - [- - -] Long (extended) Self Test duration: 5358 seconds [89.3 minutes] root@IMB-FreeNAS[~]# smartctl -a /dev/da7 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: MBF2600RC Revision: SB27 Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Rotation Rate: 10025 rpm Form Factor: 2.5 inches Logical Unit id: 0x50000393a82070b8 Serial number: EA09PBB0G8P5 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:12:33 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 36 C Drive Trip Temperature: 65 C Manufactured in week 46 of year 2011 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 47 Specified load-unload count over device lifetime: 200000 Accumulated load-unload cycles: 0 Elements in grown defect list: 0 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 4 0 0 0 1792929.478 0 write: 0 1 0 0 0 87219.517 0 verify: 0 0 0 0 0 35020.846 0 Non-medium error count: 95 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 1 - [- - -] Long (extended) Self Test duration: 5358 seconds [89.3 minutes] root@IMB-FreeNAS[~]# smartctl -a /dev/da8 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-ESXS Product: HUC109060CSS60 Revision: J2EE Compliance: SPC-4 User Capacity: 600,127,266,816 bytes [600 GB] Logical block size: 512 bytes Formatted with type 2 protection Rotation Rate: 10000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000cca043a34234 Serial number: KSJWTBUJ Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sat Jun 22 20:12:54 2019 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 32 C Drive Trip Temperature: 65 C Manufactured in week 04 of year 2014 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 5 Specified load-unload count over device lifetime: 600000 Accumulated load-unload cycles: 948 Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 12060162621702144 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 0 0 0 55536193 66535.085 0 write: 0 0 0 0 277205 26396.090 0 verify: 0 0 0 0 80751 18514.205 0 Non-medium error count: 0 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 0 - [- - -] Long (extended) Self Test duration: 4882 seconds [81.4 minutes]
