someone1
- Jun 17, 2013
Hello All!
I'm running FreeNAS 8.3.0 with 5x3TB in RAIDZ1 configuration. One of my drives failed and I finally got around to RMAing it. This is for my own home server, so its not "mission critical" but it has a ton of information I'd rather not lose.
During the resilvering process, another HDD failed (started clicking). So it looks like some of my data is accessible, but there are a ton of errors remaining on the disk and entire datasets are inaccessible. I'm trying to identify the files affected and seeing if I have backups of them, but it looks as if I can't finish the "detach" of the original failed drive. It complains about insufficient replicas exist. That drive was already offline'd before I replaced it, so its not like that drive is being used as a replica anyway?
Even if I replace the second failed drive, I am sure that my missing data is gone. My question is, what do I do about the first drive I tried replacing? It still shows it as offline, but I can't detach it. I'm tempted to copy all the data off of the drives and wipe out the array and rebuild it from scratch. I'd probably also run each drive through SeaTools to make sure there aren't any more issues with any of them (is there a built-in tool in FreeNAS to do a sector-by-sector scan and attempt to fix it?)
Wondering if there's a way to try and recover my current array or just copy what I can and pull the rest from backups (or re-create them) and start from a fresh install.
P.S. It is my own fault for waiting so long before I decided to replace the failed drive (talking months here). This is by no means a poor reflection on FreeNAS or ZFS, just a result of my laziness.
