Seagate Archive 8TB [Discussion moved]
Arwen
I just got my Seagate Archive 8TB SMR, (Shingled Magnetic Recording), drive.
Here is my setup;
Source system:
  • FreeNAS Mini
  • 4 x 4TB WD Reds in RAID-Z2
Destination:
  • Backups only
  • eSATA port on FreeNAS Mini
  • eSATA enclosure
  • Seagate Archive 8TB SMR drive as own ZFS pool
That all seems to work. Just ran my first backup, which is 1TB of used space on the FreeNAS.
I made the copy with "rsync" crossing mount points, which at end said it averaged 33MB per
second :-(. Oh, well. Was not planning on any other use except backing up my FreeNAS.
One thing I think could have helped is TRIM / DISCARD support in the Seagate SMR drive. If
the drive knew what was not in use, then their would be less need to move data around. Since
ZFS supports TRIM / DISCARD, as well as COW, (Copy On Write), these SMR drives could
really work well for ZFS writes.
Note that I REALLY wanted to use a checksumming file system like ZFS or BTRFS for this SMR
drive. That way I have a chance to detect bad data caused by firmware bugs. So as part of my
backup routine, I'll run a scrub before I start the next backup.
marbus90
Try with ZFS send | receive. That's not touching individual files but streaming a full ZFS snapshot over to the new drive, which helps with the speed.
diedrichg
Was there a question in the op?
Tywin
Agreed, I would like to see this metric as well. I would also have liked to see some dd tests to get an idea of the raw sequential speeds, but no need to wipe your data now ;)
diedrichg
Doesn't need to be. There's a big fat tag "DISCUSSION" next to the Thread Title.
Can't see that on Tapatalk, but thanks for putting me in my place.
Arwen
Yes, my eventual plan is to make the 8TB drive have the same ZFS datasets, (though without the various sharing attributes), as the source. Then script a series of "zfs send" / "zfs receive" per dataset. (Plus, give me a nice log file with times and any errors. And I always read my logs after backups.)
As for general speed, I can probably do some read tests.
In fact, if my little, low power server comes in sooner than the 5 weeks I was quoted, I can backup to it. That would give me confidence to wipe the 8TB drive and perform more write tests.
But in the mean time, I have a SSD firmware update to do, un-related to FreeNAS. Except that the FreeNAS is my backups! (My SSD is slowing down due to a firmware bug, so I need multiple backups before I perform the update.)
