Scrub times
Wolfeman0101
So slow...
[root@nibbler] ~# zpool status -v
  pool: Vol1
 state: ONLINE
  scan: scrub repaired 352K in 69h51m with 0 errors on Sat Nov  3 21:53:07 2012
        Vol1                                            ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/6dd242a6-cafb-11e1-915d-001517a03d00  ONLINE       0     0     0
            gptid/6e71f8fa-cafb-11e1-915d-001517a03d00  ONLINE       0     0     0
            gptid/6f39b462-cafb-11e1-915d-001517a03d00  ONLINE       0     0     0
            gptid/6feb82b0-cafb-11e1-915d-001517a03d00  ONLINE       0     0     0
            gptid/709a11f8-cafb-11e1-915d-001517a03d00  ONLINE       0     0     0
            gptid/713a3786-cafb-11e1-915d-001517a03d00  ONLINE       0     0     0
errors: No known data errors
During the scrub I ran a gstat and it looks like ada4 and ada5 are maxing out.
dT: 1.001s  w: 1.000s  filter: ada
 L(q)  ops/s    r/s   kBps   ms/r    w/s   kBps   ms/w   %busy Name
    0    243    233   8728    2.8     10     84    0.9   26.7| ada0
    0    252    242   8920    3.5     10     84    0.9   29.3| ada1
    0      0      0      0    0.0      0      0    0.0    0.0| ada0p1
    0    243    233   8728    2.8     10     84    0.9   26.9| ada0p2
    0      0      0      0    0.0      0      0    0.0    0.0| ada1p1
    0    252    242   8920    3.5     10     84    1.0   29.6| ada1p2
    0    247    237   8728    2.8     10     84    0.3   26.0| ada2
    0    236    226   8728    2.8     10     84    0.3   25.9| ada3
    4    119    113   9651   85.2      6     48   35.3  100.1| ada4
    5    118    113   9871   86.7      5     48   27.4  102.2| ada5
    0      0      0      0    0.0      0      0    0.0    0.0| ada2p1
    0    247    237   8728    2.8     10     84    0.4   26.2| ada2p2
    0      0      0      0    0.0      0      0    0.0    0.0| ada3p1
    0    236    226   8728    2.9     10     84    0.4   26.1| ada3p2
    0      0      0      0    0.0      0      0    0.0    0.0| ada4p1
    4    119    113   9651   85.2      6     48   35.3  100.1| ada4p2
    0      0      0      0    0.0      0      0    0.0    0.0| ada5p1
    5    118    113   9871   86.7      5     48   27.4  102.2| ada5p2
paleoN
At that moment in time or regularly? If the latter that's something you want to address. Two under performing drives will certainly pull down the performance of the entire array.
From an SSH session as root the output of:
smartctl -q noserial -a /dev/ada4
smartctl -q noserial -a /dev/ada5
FYI, an easier to read gstat:
gstat -I1s -f ada.$
Also, limiting vfs.zfs.vdev.max_pending to 5 may improve latencies for other activities during the scrub, but it will not improve scrub times. If anything they will take slightly longer.
Wolfeman0101
gstat -I1s -f ada.$
Well it was during the scrub but is there a way to put some load on the drives and see if 4 & 5 are acting up? Thanks for the gstat tip.
[root@nibbler] ~# smartctl -q noserial -a /dev/ada4
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family:     Western Digital Caviar Green (Adv. Format)
Device Model:     WDC WD20EARX-00PASB0
Firmware Version: 51.0AB51
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
ATA Version is:   8
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Fri Nov  9 20:01:24 2012 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x85)	Offline data collection activity
					was aborted by an interrupting command from host.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(38460) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 371) minutes.
Conveyance self-test routine
recommended polling time: 	 (   5) minutes.
SCT capabilities: 	       (0x3035)	SCT Status supported.
					SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       1
  3 Spin_Up_Time            0x0027   201   164   021    Pre-fail  Always       -       4950
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       56
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always       -       2873
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       54
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       50
193 Load_Cycle_Count        0x0032   195   195   000    Old_age   Always       -       16585
194 Temperature_Celsius     0x0022   119   098   000    Old_age   Always       -       31
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      2858         -
# 2  Short offline       Completed without error       00%      2835         -
# 3  Short offline       Completed without error       00%      2811         -
# 4  Short offline       Completed without error       00%      2787         -
# 5  Short offline       Completed without error       00%      2770         -
# 6  Short offline       Completed without error       00%      2744         -
# 7  Short offline       Completed without error       00%      2736         -
# 8  Short offline       Completed without error       00%      2699         -
# 9  Short offline       Completed without error       00%      2695         -
#10  Short offline       Completed without error       00%      2648         -
#11  Short offline       Completed without error       00%      2576         -
#12  Short offline       Completed without error       00%      2553         -
#13  Short offline       Completed without error       00%      2529         -
#14  Short offline       Completed without error       00%      2505         -
#15  Short offline       Completed without error       00%      2481         -
#16  Short offline       Completed without error       00%      2457         -
#17  Short offline       Completed without error       00%      2433         -
#18  Short offline       Completed without error       00%      2409         -
#19  Short offline       Completed without error       00%      2385         -
#20  Short offline       Completed without error       00%      2361         -
#21  Short offline       Completed without error       00%      2338         -
[root@nibbler] ~# smartctl -q noserial -a /dev/ada5
ATA Version is:   8
Local Time is:    Fri Nov  9 20:03:43 2012 PST
					been run.
data collection: 		(38160) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 368) minutes.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   204   168   021    Pre-fail  Always       -       4775
193 Load_Cycle_Count        0x0032   196   196   000    Old_age   Always       -       14699
194 Temperature_Celsius     0x0022   121   101   000    Old_age   Always       -       29
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
No Errors Logged
# 1  Short offline       Completed without error       00%      2859         -
# 6  Short offline       Completed without error       00%      2745         -
# 7  Short offline       Completed without error       00%      2737         -
# 8  Short offline       Completed without error       00%      2700         -
# 9  Short offline       Completed without error       00%      2696         -
#10  Short offline       Completed without error       00%      2649         -
#11  Short offline       Completed without error       00%      2577         -
#16  Short offline       Completed without error       00%      2458         -
#17  Short offline       Completed without error       00%      2434         -
#18  Short offline       Completed without error       00%      2410         -
#19  Short offline       Completed without error       00%      2386         -
#20  Short offline       Completed without error       00%      2362         -
paleoN
A scrub is quite intensive. You can also run the dd commands from the [thread=981]performance sticky[/thread]. The main thing is to read/write large files or always read new files to make sure you are hitting the disks.
Speaking of, they both appear fine. I would wdiddle them if you haven't already. Disk ada4 has 199 UDMA_CRC_Error_Count with a value of 1. You want this zero. Given its total power on hours it certainly should be zero. It's only 1 so it may just have been a fluke. I wouldn't worry about it, but I would keep an eye on it.
AFAIK, the short SMART tests are fairly worthless with these drives. They properly update their attributes automatically. Switch them to long tests and don't run them daily.
Just out of curiosity, is there a recommended schedule for long tests?
Wolfeman0101
I have no idea how to run WDIDLE. Any tips?
My tip would be to go read up on it and set it up if you haven't already. You might not be too happy if you start getting SMART failures that you can't correct because of the head parking count(or whatever it is). You'll have to use a DOS boot disk since WDIDLE only runs from DOS.
paleoN
Not really, aside from less then daily and more often then yearly. Personally I run them weekly when nothing else is going on. How much data you have & how often you scrub can come into play as well. If your disks are mostly full and you scrub often then you are already reading most of the disk surface.
Assuming your server isn't heavily accessed 24x7 I would run them at least monthly.
Wolfeman0101
So I'm bumping my old thread again. I figure that's better than a new one.
Can someone walk me through figuring out why my scrubs only happen at about 40Mb/s? If it's the CPU I'll go get a new one but I want to be sure that'll help. I just can't seem to figure out why scrubs are sooooo sllooowoowow.
Literally, there are dozens of reasons why scrubs can be slow. The number of possible causes are almost endless.
Wolfeman0101
lol.. walking through how to find that problem is like writing a 20 page book. Literally, there are dozens of reasons why scrubs can be slow.
What you are asking for is like a gamer asking why he can't get 60fps from his game. The number of possible causes are almost endless.
Oh yeah help me with my FPS too :p
I know my disks are crappy consumer level so I'm never going to get crazy speeds. I guess my 2 questions are how can I look at my CPU performance over time and during a scrub to see if the CPU is getting pegged and also are any of my disks causing slowness and maybe need to be replaced.
I'm crappy consumer level and I have no problems. I do almost 1GB/sec during scrubs on my pool. :)
It's not about the disk. In fact, its rarely about the disks. It's more about the overall system design and finding the bottleneck. There's tons of places it can be, both software and hardware.
titan_rw
I also have consumer drives and hit 1.1 - 1.2 GB/sec during scrub.
A fragmented zpool can slow down scrubs. I cut scrub times by more than half by removing 10% of total pool data one time.
I'd suggest starting a scrub manually, and investigating what the bottleneck is. Check "top -SH", and "gstat" and such.
Wolfeman0101
Maybe it's the onboard controller and the CPU. I need to find a 6 port SATA PCI-X card. What CPU do you use?
last pid:  8614;  load averages:  0.14,  0.19,  0.21                        up 0+00:30:01  11:26:25
469 processes: 5 running, 443 sleeping, 21 waiting
CPU:  0.5% user,  0.0% nice,  4.4% system,  0.4% interrupt, 94.7% idle
Mem: 388M Active, 344M Inact, 1018M Wired, 1168K Cache, 94M Buf, 14G Free
ARC: 445M Total, 150M MFU, 260M MRU, 2096K Anon, 6174K Header, 27M Other
Swap: 12G Total, 12G Free
  PID USERNAME   PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
   11 root       155 ki31     0K    64K CPU3    3  28:21 100.00% idle{idle: cpu3}
   11 root       155 ki31     0K    64K CPU2    2  28:53 96.09% idle{idle: cpu2}
   11 root       155 ki31     0K    64K RUN     0  28:27 95.75% idle{idle: cpu0}
   11 root       155 ki31     0K    64K CPU1    1  27:49 91.46% idle{idle: cpu1}
    0 root       -16    0     0K  2768K -       1   0:39  4.79% kernel{zio_read_intr_2}
    0 root       -16    0     0K  2768K -       3   0:39  4.69% kernel{zio_read_intr_1}
    0 root       -16    0     0K  2768K -       3   0:39  4.30% kernel{zio_read_intr_0}
   12 root       -88    -     0K   336K WAIT    1   0:16  1.27% intr{irq15: ata1}
 4526    816      21    0   302M   107M select  1   0:17  1.17% python2.7{python2.7}
 4526    816      21    0   302M   107M select  1   0:12  1.07% python2.7{python2.7}
   14 root        -8    -     0K    48K -       2   0:12  0.59% geom{g_down}
   12 root       -88    -     0K   336K WAIT    3   0:09  0.20% intr{irq22: ahci0}
  292 root        -8    -     0K    96K spa->s  1   0:07  0.10% zfskern{txg_thread_enter}
    0 root       -16    0     0K  2768K swapin  3   1:59  0.00% kernel{swapper}
 4526    816      20    0   302M   107M usem    3   0:21  0.00% python2.7{python2.7}
 4526    816      20    0   302M   107M usem    2   0:12  0.00% python2.7{python2.7}
 4526    816      20    0   302M   107M usem    0   0:09  0.00% python2.7{python2.7}
   14 root        -8    -     0K    48K -       2   0:07  0.00% geom{g_up}
    0 root       -92    0     0K  2768K -       0   0:03  0.00% kernel{dummynet}
 6758    972      52   15   265M 79000K piperd  3   0:03  0.00% python{python}
   12 root       -60    -     0K   336K WAIT    1   0:02  0.00% intr{swi4: clock}
 6802    972      52    0   207M 44836K piperd  1   0:02  0.00% python{python}
 2526 root        20    0   260M 94164K usem    2   0:01  0.00% python2.7{python2.7}
    5 root       -16    -     0K    16K ccb_sc  0   0:01  0.00% xpt_thrd
 4594    816      20    0   236M 81656K kqread  2   0:01  0.00% python2.7{python2.7}
 4594    816      20    0   236M 81656K select  3   0:01  0.00% python2.7{python2.7}
 4526    816      20    0   302M   107M select  1   0:01  0.00% python2.7{python2.7}
   15 root       -16    -     0K    16K -       1   0:01  0.00% yarrow
    2    171    122  6793    6.0    47    444    0.2  53.7| ada0
    2    171    122  6793    6.0    47    444    0.2  53.7| ada0p2
    2    170    120  7297    6.2    48    468    0.2  52.8| ada1
    2    162    115  7756    7.2    45    468    0.2  58.4| ada2
    2    152    104  7233    8.2    46    468    0.2  57.1| ada3
    2    136    86  7700  17.6    48    491    0.3  88.3| ada4
    2    139    91  7904  17.8    46    460    0.3  97.6| ada5
    0      0      0      0    0.0      0      0    0.0    0.0| ada1p1.eli
    2    171    122  6793    6.0    47    444    0.2  53.8| gptid/6dd242a6-cafb-11e1-915d-001517a03d00
    2    170    120  7297    6.2    48    468    0.2  52.9| ada1p2
    2    162    115  7756    7.2    45    468    0.2  58.4| ada2p2
    2    152    104  7233    8.2    46    468    0.2  57.1| ada3p2
    2    136    86  7700  17.6    48    491    0.3  88.4| ada4p2
    2    139    91  7904  17.8    46    460    0.3  97.6| ada5p2
    0      0      0      0    0.0      0      0    0.0    0.0| ada2p1.eli
    2    170    120  7297    6.2    48    468    0.2  52.9| gptid/6e71f8fa-cafb-11e1-915d-001517a03d00
    0      0      0      0    0.0      0      0    0.0    0.0| ada3p1.eli
    2    162    115  7756    7.2    45    468    0.2  58.5| gptid/6f39b462-cafb-11e1-915d-001517a03d00
    0      0      0      0    0.0      0      0    0.0    0.0| ada4p1.eli
    2    152    104  7233    8.2    46    468    0.2  57.1| gptid/6feb82b0-cafb-11e1-915d-001517a03d00
    0      0      0      0    0.0      0      0    0.0    0.0| ada5p1.eli
    2    136    86  7700  17.6    48    491    0.3  88.4| gptid/709a11f8-cafb-11e1-915d-001517a03d00
    2    139    91  7904  17.9    46    460    0.3  97.6| gptid/713a3786-cafb-11e1-915d-001517a03d00
    0      0      0      0    0.0      0      0    0.0    0.0| da0
    0      0      0      0    0.0      0      0    0.0    0.0| da0s1
    0      0      0      0    0.0      0      0    0.0    0.0| da0s2
    0      0      0      0    0.0      0      0    0.0    0.0| da0s3
    0      0      0      0    0.0      0      0    0.0    0.0| da0s4
    0      0      0      0    0.0      0      0    0.0    0.0| da0s1a
    0      0      0      0    0.0      0      0    0.0    0.0| da0s2a
    0      0      0      0    0.0      0      0    0.0    0.0| ufs/FreeNASs3
    0      0      0      0    0.0      0      0    0.0    0.0| ada0p1.eli
    0      0      0      0    0.0      0      0    0.0    0.0| ufs/FreeNASs4
    0      0      0      0    0.0      0      0    0.0    0.0| ufs/FreeNASs1a
    0      0      0      0    0.0      0      0    0.0    0.0| ufsid/521c684590455604
    0      0      0      0    0.0      0      0    0.0    0.0| ufs/FreeNASs2a
    0      0      0      0    0.0      0      0    0.0    0.0| md0
    0      0      0      0    0.0      0      0    0.0    0.0| md1
    0      0      0      0    0.0      0      0    0.0    0.0| md2
I have an Intel Xeon e3-1230v2. Full fledged CPU.
titan_rw
Cpu usage looks fine.
It looks like ada4 and ada5 are holding back the pool. At least at that particular moment in time.
Wolfeman0101
Yeah I think at one point I thought those 2 were an issue but I lost momentum on fixing it. I'm going to check them later once I'm home.
titan_rw
Not that the drives are necessarily bad. Just that at that moment, those 2 drives were being 'loaded' more than the others. I see that at times in my pools too. If it very consistently those two drives, it might be the drives. I suppose it could be data distribution on the drives too, depending on the pool layout.
Wolfeman0101
I just know in the past those 2 drives have seemed to be a bottleneck as well. I wonder if the drive is bad or the cable or the controller.
Starpulkka
My system:
AMD FX(tm)-4100 Quad-Core Processor
16GB DDR3 ECC RAM
Onboard controller
state: ONLINE
  scan: scrub repaired 0 in 6h1m with 0 errors on Sun Jan 26 06:01:58 2014
        NAME                                            STATE    READ WRITE CKSUM
        *****                                          ONLINE      0    0    0
            gptid/5a0644da-b996-11e2-89c4-60a44c57d49e  ONLINE      0    0    0
            gptid/5a867495-b996-11e2-89c4-60a44c57d49e  ONLINE      0    0    0
            gptid/5bd3c295-b996-11e2-89c4-60a44c57d49e  ONLINE      0    0    0
            gptid/5c5e1e41-b996-11e2-89c4-60a44c57d49e  ONLINE      0    0    0
            gptid/5ce1d74d-b996-11e2-89c4-60a44c57d49e  ONLINE      0    0    0
            gptid/5d69fbe3-b996-11e2-89c4-60a44c57d49e  ONLINE      0    0    0
Edit: oh and pool is 70%full
Do you have system folder on? If my pool would take over 7h i would be worried, very worried of my pool. But in your case your pool has always take that long time to scrub so nothing new failure have not yet happened.
Go to your motherboard bios and check have you enabled achi on sata 5 and 6 ports. looks like that 1-4 is on achi mode and 5-6 ports are not.
Edit: I know also some more speed options but its not worth now on your pool,(pool needs to be re create so i dont recommend it) perhaps next pool then you build it right. from the start.
