- Aug 16, 2011
You can do what Basil told you to do: attach the complete nextcloud.log. He told you how to get it, too (as do I in the README).how i can resolve?
root@truenas[~/freenas-iocage-nextcloud]# ls -lR total 54 drwxr-xr-x 8 root wheel 13 Aug 9 22:41 .git -rw-r--r-- 1 root wheel 66 Aug 9 22:41 .gitignore drwxr-xr-x 2 root wheel 2 Aug 11 03:02 includes -rw-r--r-- 1 root wheel 35147 Aug 9 22:41 LICENSE -rw-r--r-- 1 root wheel 417 Aug 16 21:40 nextcloud-config -rwxr-xr-x 1 root wheel 22263 Aug 11 23:02 nextcloud-jail.sh -rw-r--r-- 1 root wheel 31308 Aug 16 21:52 nextcloud.log -rw-r--r-- 1 root wheel 13583 Aug 9 22:41 README.md ./.git: total 9 drwxr-xr-x 2 root wheel 2 Aug 9 22:41 branches -rw-r--r-- 1 root wheel 275 Aug 9 22:41 config -rw-r--r-- 1 root wheel 73 Aug 9 22:41 description -rw-r--r-- 1 root wheel 23 Aug 9 22:41 HEAD drwxr-xr-x 2 root wheel 14 Aug 9 22:41 hooks -rw-r--r-- 1 root wheel 1524 Aug 9 22:41 index drwxr-xr-x 2 root wheel 3 Aug 9 22:41 info drwxr-xr-x 3 root wheel 4 Aug 9 22:41 logs drwxr-xr-x 4 root wheel 4 Aug 9 22:41 objects -rw-r--r-- 1 root wheel 194 Aug 9 22:41 packed-refs drwxr-xr-x 5 root wheel 5 Aug 9 22:41 refs ./.git/branches: total 0 ./.git/hooks: total 22 -rwxr-xr-x 1 root wheel 478 Aug 9 22:41 applypatch-msg.sample -rwxr-xr-x 1 root wheel 896 Aug 9 22:41 commit-msg.sample -rwxr-xr-x 1 root wheel 4661 Aug 9 22:41 fsmonitor-watchman.sample -rwxr-xr-x 1 root wheel 189 Aug 9 22:41 post-update.sample -rwxr-xr-x 1 root wheel 424 Aug 9 22:41 pre-applypatch.sample -rwxr-xr-x 1 root wheel 1643 Aug 9 22:41 pre-commit.sample -rwxr-xr-x 1 root wheel 416 Aug 9 22:41 pre-merge-commit.sample -rwxr-xr-x 1 root wheel 1348 Aug 9 22:41 pre-push.sample -rwxr-xr-x 1 root wheel 4885 Aug 9 22:41 pre-rebase.sample -rwxr-xr-x 1 root wheel 544 Aug 9 22:41 pre-receive.sample -rwxr-xr-x 1 root wheel 1453 Aug 9 22:41 prepare-commit-msg.sample -rwxr-xr-x 1 root wheel 3635 Aug 9 22:41 update.sample ./.git/info: total 1 -rw-r--r-- 1 root wheel 240 Aug 9 22:41 exclude ./.git/logs: total 2 -rw-r--r-- 1 root wheel 188 Aug 9 22:41 HEAD drwxr-xr-x 4 root wheel 4 Aug 9 22:41 refs ./.git/logs/refs: total 1 drwxr-xr-x 2 root wheel 3 Aug 9 22:41 heads drwxr-xr-x 3 root wheel 3 Aug 9 22:41 remotes ./.git/logs/refs/heads: total 1 -rw-r--r-- 1 root wheel 188 Aug 9 22:41 master ./.git/logs/refs/remotes: total 1 drwxr-xr-x 2 root wheel 3 Aug 9 22:41 origin ./.git/logs/refs/remotes/origin: total 1 -rw-r--r-- 1 root wheel 188 Aug 9 22:41 HEAD ./.git/objects: total 10 drwxr-xr-x 2 root wheel 2 Aug 9 22:41 info drwxr-xr-x 2 root wheel 4 Aug 9 22:41 pack ./.git/objects/info: total 0 ./.git/objects/pack: total 13858 -r--r--r-- 1 root wheel 22996 Aug 9 22:41 pack-cde9ebb8e7ee9bbcecb4e0585e0b35cd12d57b9b.idx -r--r--r-- 1 root wheel 14156739 Aug 9 22:41 pack-cde9ebb8e7ee9bbcecb4e0585e0b35cd12d57b9b.pack ./.git/refs: total 2 drwxr-xr-x 2 root wheel 3 Aug 9 22:41 heads drwxr-xr-x 3 root wheel 3 Aug 9 22:41 remotes drwxr-xr-x 2 root wheel 2 Aug 9 22:41 tags ./.git/refs/heads: total 1 -rw-r--r-- 1 root wheel 41 Aug 9 22:41 master ./.git/refs/remotes: total 1 drwxr-xr-x 2 root wheel 3 Aug 9 22:41 origin ./.git/refs/remotes/origin: total 1 -rw-r--r-- 1 root wheel 32 Aug 9 22:41 HEAD ./.git/refs/tags: total 0 ./includes: total 0
Well, there's your problem, though I have no idea how it would have happened. There should be a number of files there (see https://github.com/danb35/freenas-iocage-nextcloud/tree/master/includes). At this point, I'd suggest saving a copy of your nextcloud-config file, deleting the entire script directory, and downloading the script again with./includes:
total 0
git clone https://github.com/danb35/freenas-iocage-nextcloud.
- Initializing
Current version is 15.0.5.
Update to Nextcloud 16.0.11 available. (channel: "stable")
Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-16.0.11.zip
Retry update- Check for expected files
- Check for write permissions
The following places can not be written to:
- /var/www/nextcloud/updater/../AUTHORS
- /var/www/nextcloud/updater/../robots.txt
- /var/www/nextcloud/updater/../index.php
- /var/www/nextcloud/updater/../public.php
- /var/www/nextcloud/updater/../remote.php
- /var/www/nextcloud/updater/../occ
- /var/www/nextcloud/updater/../.htaccess
- /var/www/nextcloud/updater/../.user.ini
- /var/www/nextcloud/updater/../COPYING
- /var/www/nextcloud/updater/../version.php
- /var/www/nextcloud/updater/../cron.php
- /var/www/nextcloud/updater/../index.html
- /var/www/nextcloud/updater/../console.php
- /var/www/nextcloud/updater/../status.php
chown -R www:www /usr/local/www/nextcloud. There's no need for sudo; you're running as root anyway.Thanks for the reply, www is the owner of that area already, and the issue is still there.If you installed using my script, Nextcloud will be in /usr/local/www/nextcloud, and the correct user would be www. That would make the correct commandchown -R www:www /usr/local/www/nextcloud. There's no need for sudo; you're running as root anyway.
Why would you think that might possibly help? If there isn't a www-data user (and if you used my script--which I note you haven't yet answered--there isn't), the fact that the Nextcloud files aren't owned by that user can't possibly be the source of the problem.might create the www-data account and group and change ownership to see if it helps it?
Yes, through theor is there a way of updating not through the webgui ?
occ command. su -m www -c 'php /usr/local/www/nextcloud/occ upgrade' should do it.Did you run the command @danb35 gave you? It recursively sets the permissions to all files and directories withinThanks for the reply, www is the owner of that area already, and the issue is still there.
I might create the www-data account and group and change ownership to see if it helps it? if not I will change it back
/usr/local/www/nextcloud to www:www. Unless you're saying that you checked every one of those files and they are all owned by the www user and group. The other thing to check is the permissions - what is the output of ls -al /var/www/nextcloud/updater/../occ (insert the full/appropriate path) - make sure the www user has the write bit set.www-data user and group and changing ownership to these will do nothing. These are the defaults in a linux environment. In BSD the default is www. The web server will be running as the www user, not www-data.understand that, i was only going of what the general google answer for the error below saysWhy would you think that might possibly help? If there isn't a www-data user (and if you used my script--which I note you haven't yet answered--there isn't), the fact that the Nextcloud files aren't owned by that user can't possibly be the source of the problem.
Yes, through the occ command. su -m www -c 'php /usr/local/www/nextcloud/occ upgrade' should do it.
root@verulamcloud:~ # su -m www -c 'php /usr/local/www/nextcloud/occ upgrade'
Nextcloud is already latest version
it says in the general setting that 15.0.0.5Initializing
root@verulamcloud:~ # ls -al /var/www/nextcloud/updater/../occ
ls: /var/www/nextcloud/updater/../occ: No such file or directory
root@verulamcloud:~ # ls -al /usr/local/www/nextcloud/updater/../occ
-rw-r--r-- 1 www www 283 Jun 12 07:46 /usr/local/www/nextcloud/updater/../occ
root@verulamcloud:~ # mount
Jails-VMs/iocage/jails/versamcloud/root on / (zfs, local. nfsv4acls)
yes, 100% if there's a way to check i can for youDid you install using my script?
Hmmm. As I'm digging into the state of my script two years ago, I'm thinking you didn't--it looks like I'd been placing the Nextcloud files inif there's a way to check i can for you
/usr/local/www/apache24/data/nextcloud, which doesn't match what you're seeing. I didn't start putting them in /usr/local/www/nextcloud until I made the switch to Caddy with Nextcloud 16, as best I can tell, and since you aren't using Nextcloud 16, you wouldn't be using Caddy with my script.iocage fstab -l <jailname>?Try running the follwoing command within your jail:understand that, i was only going of what the general google answer for the error below says
could it be that a link has gone as it's looking for /var/www and not usr/local/www ? like a mount point?
tried this and in the console and for the below output
the webgui says
The version you are running is not maintained anymore. Please make sure to update to a supported version as soon as possible
output of
ls -al /usr/local/www/nextcloud/updater/../occ not ls -al /var/www/nextcloud/updater/../occ as it can't find that path
says
(again is this a link issue as the var/www/nextcloud/updater/../occ isn't reachable?)
mount only shows root to the local disk on freenas
sorry my knowledge on these things are limited so I do appreciate your help.
find /usr -name "occ"'overwrite.cli.url' => 'https://nextssl.xxxx.net/' 'trusted_proxies' => ['172.16.1.1'], 'overwritehost' => 'nextssl.xxxx.net', 'overwritewebroot' => '/', 'overwriteprotocol' => 'https', 'overwritecondaddr' => '^172.16.1.1$',
