Hi there,
I used danb35 script to install nextcloud on my TrueNAS Core - TrueNAS-13.0-U6.1.
I did everything in the preconfiguration steps, I went for the 1 Dataset named nextcloud Under which you create 4 other datasets : files, config, themes, db
I opened the required ports too.
My main pool (the root) is called "Nextcloud", and within it I created the "nextcloud" dataset with the 4 subs.
However, in the config text bloc i mistakenly wrote this :
POOL_PATH="/mnt/Nextcloud/nextcloud/db"
I should have done :
POOL_PATH="/mnt/Nextcloud"
I ran the script, everything seems to work fine, i can access the nextcloud config page via my domain name, however, the datasets now
look like this : nextcloud/db/nextcloud/db, and in that i have the mariadb
I want to start the installation over so I can properly set the datasets, can I just delete the jail and the folders and re-run the script ?
Or will it mess up something else behind ? (ports, ip addresses, lets encrypt certificates, etc) ?
Thanks !
in this db dataset, there's another "nextcloud/db/"
