Trying to automate the backup/restore of my plex data directory. Here is the script. I thought I would share it case it helps. Will make a task in the GUI to run it daily.
Edit: added option to backup without user input by setting cron="yes"
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
