I am wondering if Scale 22.12.0 virtualization support 12th integrated CPU. My virtualization shows "Your CPU does not support KVM extensions."
Following the Release Note:
I checked my compatible controller
So I set the value to 4692, but VM still could not run. Can I get some tips?
TrueNAS SCALE Bluefin includes Linux Kernel 5.15 which can enable Alderlake GPU acceleration by using the following boot loader tunable and rebooting:
midclt call system.advanced.update '{"kernel_extra_options": "i915.force_probe=4690" }'
NOTE: 4690 can be replaced with your specific Alderlake GPU version.
$ lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation Device 4692 (rev 0c)
