SOLVED SCALE 22.02.4 -> 22.12 Boot Stuck
Conor Calby
Hi All,
I have just applied an update to my TrueNAS Scale, moving from 22.02.4 to 22.12.0.
The server will no longer boot - stuck on this output for the past 2 hours.
(P.S. The time to even boot into the upgrade was insane!)
Hardware:
CPU: AMD Ryzen 5 5500 AM4
PSU:Can't remember, but working.
Motherboard: MSI MAG B550 TOMAHAWK DDR4 ATX
Graphics Card: Radeon RX 550 4GB Graphics Card GDDR5
RAM: Kingston FURY Beast 16GB (2 x 8GB) 3200MHz DDR4 RAM
Hard Drives: 1x 120GB SSD (boot-pool), 3x 3TB drives (Raid-z1), 1x 250GB SSD (ix-applications)
Any suggestions or causes?
Interrupt the boot process and select the previous (22.04) boot environment.
Conor Calby
Same issue I'm afraid @sretalla (same output and hang - including message it's updating).
Will try and reinstall 22.02.4 and then attempt upgrade again.
If you're going to reinstall... just install the new version and restore your config on that.
Conor Calby
Resolved.
Downloaded 22.12.0 and burned to USB.
Fresh install (inc. format boot SSD drive).
22.12.0 loaded with no problems.
Imported old config.
Still working.
Disabled "Enable Serial Console" as per:
