- Feb 2, 2018
My actual specs are provided at the end of this message.
About 8 months ago, I bought all my drives at once, so they will probably all fail at once
To avoid that, I bought a new one, 3TB instead of 1. I will keep replacing my disks progressively, so they will not fail all together. At the end, I will have a pool 3 times bigger.
FreeNAS is the backend for my Nextcloud service, running from a separate server. I also have a Plex jail running. Because of that, all my multimedia stuff, files, agendas, calendars and more are in my FreeNAS. With my pool of 1 TB disks, I already have plenty of space. I am using 19% of it. I do plan to add a lot of data, but really the pool with 1TB drives was enough. So once with 3 TB drives, I will have way more space than needed.
I thought about using that extra space to increase the redundancy for my data by having 2 copies of everything. For that, my understanding is that ZFS can do it by itself in the background. Because my entire life is now in that server, I am looking for the maximum security. I am also working on an RSync copy of the "active" data to an offsite file server.
Questions are:
1-Can I change this setting on an existing pool and FreeNAS will start duplicating everything or is it an option available only when creating a new pool ? (how to change that setting ?)
2-I have 5 generations of snapshots (15 min -3D, 1H - 3W, 1D - 9W, 1W - 18M, 4W - 5Y). Together, they total about 950 snapshots covering 5 years. Will the copies=2 also duplicate what is currently saved in these snapshots ?
3-Other than using twice as much disk space, I expect copies=2 will also slow down write access. Any other performance effect I should consider ? (concerns about RAM?)
4-Is it an option that can be reverted ?
5-Any advice against using that option or some extra care I should take if I am about to use it ?
6-Anything special for the Plex jail ?
7-Should I wish to use ISCSI to provide storage to my ESXi 6.7 server, how this option will affect the setup ?
Thanks for your input,
Heracles
Server: Dell T-110
OS:
CPU:
RAM: 8 Gig (2x 4G)
Disks : 6 of them
Zpool:
UPS:
APC Back-UPS RS 1500
Questions are:
Heracles
Server: Dell T-110
OS:
root@atlas:~ # uname -v FreeBSD 11.1-STABLE #0 r321665+e0c4ca60dfc(freenas/11.1-stable): Wed May 30 14:18:20 EDT 2018 root@nemesis.tn.ixsystems.com:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/_BE/os/sys/FreeNAS.amd64
CPU:
root@freenas:~ # sysctl hw.ncpu hw.ncpu: 4 root@freenas:~ # sysctl hw.model hw.model: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
RAM: 8 Gig (2x 4G)
root@freenas:~ # dmidecode -t memory # dmidecode 3.1 Scanning /dev/mem for entry point. SMBIOS 2.7 present. Handle 0x0026, DMI type 16, 23 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: Multi-bit ECC Maximum Capacity: 32 GB Error Information Handle: No Error Number Of Devices: 4 Handle 0x0028, DMI type 17, 34 bytes Memory Device Array Handle: 0x0026 Error Information Handle: No Error Total Width: 128 bits Data Width: 64 bits Size: 4096 MB Form Factor: DIMM Set: None Locator: DIMM A1 Bank Locator: BANK 1 Type: DDR3 Type Detail: Synchronous Unbuffered (Unregistered) Speed: 1333 MT/s Manufacturer: 80AD000080AD Serial Number: 1C6605E9 Asset Tag: 011133 Part Number: HMT351U7BFR8A-H9 Rank: Unknown Configured Clock Speed: 1333 MT/s
Disks : 6 of them
root@freenas:~ # smartctl -i /dev/ada0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Device Model: Serial Number: LU WWN Device Id: 5 000c50 0a5b783eb Firmware Version: SC60 errors: No known data errors Seagate IronWolf ST1000VN002-2EY102 Z9C482NA User Capacity: Sector Sizes: Rotation Rate: Form Factor: Device is: ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri Feb 2 09:54:42 2018 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled
Zpool:
root@freenas:~ # zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:01:08 with 0 errors on Wed Jan 31 03:46:08 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors pool: vCloud state: ONLINE scan: resilvered 171G in 0 days 00:57:13 with 0 errors on Fri Feb 2 10:24:42 2018 config: 1,000,204,886,016 bytes [1.00 TB] 512 bytes logical, 4096 bytes physical 5900 rpm 3.5 inches In smartctl database [for details use: -P show] NAME vCloud raidz2-0 gptid/b6e68312-07ae-11e8-8de1-bc305be5d3f0 ONLINE gptid/16489e9d-07be-11e8-9281-bc305be5d3f0 ONLINE gptid/082cf4ad-07ea-11e8-b8b5-bc305be5d3f0 ONLINE gptid/13975389-0825-11e8-8302-bc305be5d3f0 ONLINE gptid/da2d7724-07ca-11e8-909c-bc305be5d3f0 ONLINE gptid/48ecf0c5-07d9-11e8-85bc-bc305be5d3f0 ONLINE STATE ONLINE ONLINE READ WRITE CKSUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
UPS:
