Sata controler 6x 4to
ecurgot
Hi
i want to build a freenas server with my dell poweredge T410.
I don't know what's the maximum capacity authorized on the onboard sata ports. I want to build a 6x4to but I can't find any information on the onboard chip.
If onboard ports does not work with 6x4to, I wanted to put a 6 port sata controller card in PCI-e
I understood that a marvel 88SE9215 could be a good solution. Is it right ?
such like that : https://fr.aliexpress.com/item/33016481933.html?spm=a2g0o.cart.0.0.76683c00ffUgyL&mp=1
I'm not pretty sure, but it seems that this chip can only use 4 ports on the 6.
What is your advice ?
- this card with 6x4to will be fine ?
- Use the same card in 4 ports version, and put a second one with 4 other ports ?
I'm confused.
Thanks.
This forum doesn’t have a good history with Marvell controllers. Don’t get that one.
You should use an LSI HBA as suggested in the hardware recommendations/resources section of this forum. These usually support 8 disks as a starting point but can connect more through an expander.
ecurgot
Thanks for your quick reply sretalla
Due to imperfect translation, could you link me a LSI HBA exemple on amazon, with 6 sata ports usable simultanously ?
Thank you, that will help me to undesrtant what is exactly this kind of card.
Vic.
It’s an old link, but this is the kind of card you are looking for.
ecurgot
Thanks !
Do you think all these cards are ok ? :
- card 1 (fistjutsu not LSI, but same chip LSI 9211-8I M1015) @25$
- card2 (LSI 9200-8i SAS2008) @30$
Or is it usefull to put 2 x cards 4ports on 2 pci-e ? Freenas will see the 8 drives correctly and will make same raid as in a single 8ports card ?
Thank you !
This is the best option. Don't forget that you will need the breakout cables to give 8 SATA connections.
The other options you propose will also work, but perhaps not as simply and with no real benefit for the complication.
maybe should i get this LSI 9210 and flash it for IT mode ?
The included cables look like they may not be in the best condition, but otherwise it's the number 2 best option. Make sure to flash it into IT mode if you do get it.
ecurgot
You mean 2x minisas sff8087 to 4 sata ?
at this time, my T410 got a front backplane with 6 rackable 3.5 hd. Do you think it is better to use 2 minisas from LSI 9200 directly to 8 sata port, or should i use a minisas to minisas to use the bottom of the backplane to the LSI9200?
Thanks again, your help is really appreciated
vic
Using the backplane is probably fine. I hadn't checked that for your hardware so didn't suggest it.
ecurgot
This is the back of my backplane.
I can imagine to unplug both minisas that are at this time connected to my perc 6i, and just plug to the new LSI9200 with 2 minisas to minisas. Do you think it is right ?
Sounds like it’s the right plan.
ecurgot
Nice ! I'll try it and will come back to you with my results.
A last thing, are we certain that this controler can use his 8 sata port simultanously with a 4to on each ?
The controller is capable of hundreds of disks. With a breakout cable you can get 4 disks per port, but with a backplane or expander card you can go as high as the backplane or expander allows. You can certainly run 8 disks on it.
ecurgot
With no maximum capacity defined ? My perc 6i was limited to 2to/disk so I want to be sure that 4to will be accepted
With the latest firmware (anything in the last 5 years) more than 4TB is fine for those cards.
ecurgot
Fine !
I got one more question plz Sretalla, a friend of mine wants to give me 2 cards ...
a PERC H310 and a PERC H200E
The one I choosen (LSI 92xx) is better or should I change for a H310 or H200E ?
I have seen comments in this forum indicating that PERC isn't a good match for FreeNAS.
I have no personal experience with PERC controllers so can't recommend one.
LSI is known to work well.
