SATA 2 on Mac Pro Limiting?
SwisherSweet
I'm considering building a FreeNAS on a Mac Pro 12 core but concerned that the SATA 2 spec will impeed performance. If I have 64gb of RAM will I suffer from the older SATA spec?
Will I get much more benefit from 3.46 ghz cpu vs 2.4 ghz cpu on transcoding, vm, and file serving?
I plan to use it for home Plex server, Time Machine backups now and, and a few Window VMs when 11 is released.
Thank you.
Not with spinning rust.
What will limit you is getting FreeNAS to boot in a Mac Pro. Whenever someone tries, they invariably say it's rather hard.
a few Window VMs
That's awfully optimistic. Are you sure Apple's firmware supports all of bhyve's requirements (EPT, VT-x with unrestricted guest)? Even then, you'll need the 32nm processors, because Nehalem didn't originally support these features.
SweetAndLow
Sweet'NASty
Thank you.
I don't think it will even boot on your Mac.
I also doubt any virtualization will work.
Sata2 handles 300GB/s, how fast are your hdd's? I can tell you they are not that fast, usually 150MB/s.
SwisherSweet
The Mac I'm looking at has two 3.46 Ghz 6 Core ‘Westmere’ processors. From my internet searches, it supports EPT, VT-x with unrestricted guest, and is 32nm. It does seem the 'Nehalem' CPUs would not fit the bill but the 'Westmere' will.
I read about others solving the Mac boot problem by installing FreeNAS on a physical drive. I'll have to weigh this into my decision and cost (both hard cost and space).
SwisherSweet
Thanks for your reply. Are you suggesting that the drive is limited by it's ability to physically read/write data from the plater and not by the SATA 2 interface?
With that understanding, what benefit would SATA 3 have over SATA 2?
Yes, performance differences are trivial on spinning rust.
Stux
SATA2 is only a problem on SSDs.
FWIW, I'd use a Mac Pro to run macOS. 12 core Mac Pro is still the best Mac ever made.
And they probably fetch a pretty penny on the 2nd hand market.
