SAS device not recognized
jakeblues
Hello There,
I would need some help to passthrough a SAS PCIe Card to a Windows 10 VM. It is a SAS3442E-R.
Only an external LTO-5 Tapedrive is attached. I don't need the Raid functionality.
I looked it up and it should be compatible with FreeBSD. The "PCI Passthrough Device" tab at the VM is empty though.
Physical green lights are on at the card and I know it isn't broken as I pulled it out from another PC.
Could you give me two hints:
1. Where/How can I see if the card is being recognized by FreeBSD/TrueNAS
2. Where/How can I see if the card is being recognized by the BIOS (found no device listings, only genreal settings at PCIe Tab in BIOS and IPMI only shows CPU and RAM)
Thanks a lot!
SAS1? Don't see many of those these days.
See if it shows up in lspci
jakeblues
Wow! This was fast! Yes, there it is:
02:00.0 SCSI storage controller: Broadcom / LSI SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
What could be the problem that I cannot passthrough?
Hard to say in the abstract. Is the system firmware configured to support passthrough (VT-d enabled, etc.)?
jakeblues
Figured it out! As I am still in a testing phase I switched from Core to Scale. In Scale it showed up and was immediately recognized by Windows. Guess I'll stick with Scale.
Thank you so much for your support!!!
jakeblues
I would have one last question: As described above, I'm planning to virtualize my PC where I was running backups to tape and external drives.
Is it a save way to go with Scale and Win10 VM or do you think I will loose Data because of accessing the LTO and external USB-HDDs via virtualized hardware-connections? The network-source-shares would be mounted via SMB in the VM as ZFS can't be accessed natively by WIN10. Or is there a better way to go?
There's no major issue with the concept, but why do you need Windows in the mix?
jakeblues
I saw that coming :smile:. I know that there is tar but I'm in an environment where I have to use LTFS for a fast and easy way to copy files. I know that with FreeBSD there is a GitHub Version available but I don't know how stable this is. And now that I switched to Scale I don't know if there is a Linux version for LTFS. A GUI would also be nice as I am not the only one who has to transfer the files. If there is an alternative to Windows or a simpler solution I would like to step that road.
LTFS... I only have experience with LTO3, so I never messed around with LTFS (spinning rust is slow enough for me), but I imagine it's still pretty slow, no?
jakeblues
LTFS was first introduced with LTO-5. As I'm transferring only big files write speeds (uncompressed) reach up to 60-100 MBps wich is okay. From the specs they should go as high as 280 compressed and 140 uncompressed. But I never reached those. I had a problem with shoe shining in WIN10 wich I hadn't in WIN7. Then the transfer rates went crazy slow. I guess I have to face this problem again and find a solution as I couldn't get WIN7 to work in TrueNAS Core VM (no mouse and no USB driver could be loaded from virtIO after Installation)
jakeblues
So far I could't get things done with Scale. To many bugs with the VMs. So I guess I'm back with Core. I have one trace why the SAS isn't being recognized. I searched the forum and found a hint that VT-D has to be enabled wich was already enabled and the second thing is that iommu has to be set in the kernel.
dmesg | grep -e DMAR -e IOMMU
Output shows nothing. So this is a sign that iommu is off.
The post says "intel_iommu=on"has to be enabled on the kernel command line. But I have no clou where I have to put that line in BSD.
These are the posts I'm referring to:
This would be another post where someone encounters a similar problem:
But I guess my knowledge isn't that deep for that kind of coding. I hope there is an easier fix for my problem.
Any help would be much appreciated how to get that card working.
