Bruce Payne
- Jul 21, 2016
Hi@all!
I have a problem with Samba's username mapping feature when accessing user home shares.
My home network contains some Windows 10 machines.
The user account naming pattern on these machines is "Firstname Lastname" (eg. "John Doe") as detailed in the following sample:
Each of these users also has a user account on my FreeNas box - the naming pattern here is simply "firstname", eg. "john".
To match usernames I created an additional file "smbusers", added a line for each user mapping Unix to Windows usernames and updated the Samba configuration to read this file.
Below an overview of a sample system:
Now when a user tries to access his/her home share by his/her Windows username, he/she gets an error stating that shares path could not be found.
(BTW: Does anybody know if there's a way to switch cmd temporarily to en-EN or en-US?)
Regarding the following excerpt from /var/log/samba4/log.smbd (output of connection attempt above) I assume that the username mapping feature itself seems to work (see lines 1f., 57f., 69-80, 91-95 ), but there's obviously a problem setting the correct homepath (share name resembles Windows-like username in all lowercase instead of expected Unix-type, see lines eg. 113f., 147f.):
I can prevent error messages by creating symlinks, but I don't think this is the proper way to do things:
To sum it up: I did a lot of forum and web search, read and learned a lot, fiddled around with settings and parameters but after all I still have no clue how to fix the basic problem. So any help is greatly appreciated.
Please apologize if I missed something.
Best regards,
dP
EDIT: re-formatted using CODE blocks for better readibility
C:\Users\John Doe>ver Microsoft Windows [Version 10.0.10586]
[root@server] ~# uname -a FreeBSD server.intranet.mydomain.tld 10.3-STABLE FreeBSD 10.3-STABLE #0 455d13d(9.10-STABLE): Sun Jun 26 22:47:03 PDT 2016 root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/trueos/sys/FreeNAS.amd64 amd64
[root@server] ~# groups john john [root@server] ~# ls -la /mnt/pool/homes/ total 10 drwxrwxr-x+ 3 root wheel 4 Jul 19 09:47 ./ drwxr-xr-x 3 root wheel 3 Jul 19 09:44 ../ -rw-r--r-- 1 root wheel 0 Jul 19 09:44 .windows drwxrwxr-x+ 2 john john 11 Jul 19 09:48 john/
[root@server] ~# ls -la smbusers -rw-r--r-- 1 root wheel 31 Jul 14 14:29 smbusers [root@server] ~# cat smbusers john = "John Doe"
[root@server] ~# cat /usr/local/etc/smb4.conf [global] server max protocol = SMB3 encrypt passwords = yes dns proxy = no strict locking = no oplocks = yes deadtime = 15 max log size = 51200 max open files = 586316 logging = file load printers = no printing = bsd printcap name = /dev/null disable spoolss = yes getwd cache = yes guest account = nobody map to guest = Bad User obey pam restrictions = yes directory name cache size = 0 kernel change notify = no panic action = /usr/local/libexec/samba/samba-backtrace nsupdate command = /usr/local/bin/samba-nsupdate -g server string = FreeNAS Server ea support = yes store dos attributes = yes lm announce = yes hostname lookups = yes time server = yes acl allow execute always = false dos filemode = yes multicast dns register = yes domain logons = no local master = yes idmap config *: backend = tdb idmap config *: range = 90000001-100000000 server role = standalone netbios name = WINTERMUTE workgroup = WORKGROUP security = user pid directory = /var/run/samba create mask = 0666 directory mask = 0777 client ntlmv2 auth = yes dos charset = CP437 unix charset = UTF-8 log level = 10 username map = /root/smbusers [homes] valid users = %U path = /mnt/pool/homes/%U comment = Home Directories printable = no veto files = /.snapshot/.windows/.mac/.zfs/ writeable = yes browseable = yes recycle:repository = .recycle/%U recycle:keeptree = yes recycle:versions = yes recycle:touch = yes recycle:directory_mode = 0777 recycle:subdir_mode = 0700 vfs objects = zfs_space zfsacl aio_pthread streams_xattr recycle hide dot files = yes guest ok = no nfs4:mode = special nfs4:acedup = merge nfs4:chown = true zfsacl:acesort = dontcare
C:\Users\John Doe>net view \\SERVER Freigegebene Ressourcen auf \\SERVER FreeNAS Server Freigabename Typ Verwendet als Kommentar ------------------------------------------------------------------------------- homes Platte Home Directories john Platte Home Directories Der Befehl wurde erfolgreich ausgeführt. C:\Users\John Doe>net use X: \\SERVER\john /user:"John Doe" P@ssw0rd Systemfehler 53 aufgetreten. Der Netzwerkpfad wurde nicht gefunden.
[2016/07/21 11:47:15.941069, 3] ../source3/lib/access.c:338(allow_access) Allowed connection from client.fritz.box (192.168.1.2) [2016/07/21 11:47:15.941445, 3] ../source3/smbd/oplock.c:1309(init_oplocks) init_oplocks: initializing messages. [2016/07/21 11:47:15.941630, 3] ../source3/smbd/process.c:1880(process_smb) Transaction 0 of length 159 (0 toread) [2016/07/21 11:47:15.941706, 3] ../source3/smbd/process.c:1490(switch_message) switch message SMBnegprot (pid 11766) conn 0x0 [2016/07/21 11:47:15.944199, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [PC NETWORK PROGRAM 1.0] [2016/07/21 11:47:15.944281, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [LANMAN1.0] [2016/07/21 11:47:15.944338, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [Windows for Workgroups 3.1a] [2016/07/21 11:47:15.944393, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [LM1.2X002] [2016/07/21 11:47:15.944441, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [LANMAN2.1] [2016/07/21 11:47:15.944490, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [NT LM 0.12] [2016/07/21 11:47:15.944543, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [SMB 2.002] [2016/07/21 11:47:15.944592, 3] ../source3/smbd/negprot.c:575(reply_negprot) Requested protocol [SMB 2.???] [2016/07/21 11:47:15.945130, 3] ../source3/smbd/smb2_negprot.c:269(smbd_smb2_request_process_negprot) Selected protocol SMB2_FF [2016/07/21 11:47:15.946788, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'gssapi_spnego' registered [2016/07/21 11:47:15.946864, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'gssapi_krb5' registered [2016/07/21 11:47:15.946914, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'gssapi_krb5_sasl' registered [2016/07/21 11:47:15.946964, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'spnego' registered [2016/07/21 11:47:15.947013, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'schannel' registered [2016/07/21 11:47:15.947062, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'naclrpc_as_system' registered [2016/07/21 11:47:15.947113, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'sasl-EXTERNAL' registered [2016/07/21 11:47:15.947162, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'ntlmssp' registered [2016/07/21 11:47:15.947210, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'http_basic' registered [2016/07/21 11:47:15.947259, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'http_ntlm' registered [2016/07/21 11:47:15.947308, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'krb5' registered [2016/07/21 11:47:15.947356, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'fake_gssapi_krb5' registered [2016/07/21 11:47:15.947709, 3] ../source3/smbd/negprot.c:683(reply_negprot) Selected protocol SMB 2.??? [2016/07/21 11:47:15.950033, 3] ../source3/smbd/smb2_negprot.c:269(smbd_smb2_request_process_negprot) Selected protocol SMB3_11 [2016/07/21 11:47:15.953974, 3] ../auth/ntlmssp/ntlmssp_util.c:34(debug_ntlmssp_flags) Got NTLMSSP neg_flags=0xe2088297 [2016/07/21 11:47:15.956393, 3] ../auth/ntlmssp/ntlmssp_server.c:359(ntlmssp_server_preauth) Got user=[John Doe] domain=[] workstation=[CLIENT] len1=24 len2=324 [2016/07/21 11:47:15.956486, 3] ../source3/param/loadparm.c:3730(lp_load_ex) lp_load_ex: refreshing parameters [2016/07/21 11:47:15.956737, 3] ../source3/param/loadparm.c:544(init_globals) Initialising global parameters [2016/07/21 11:47:15.957116, 3] ../source3/param/loadparm.c:2659(lp_do_section) Processing section "[global]" [2016/07/21 11:47:15.959270, 2] ../source3/param/loadparm.c:2676(lp_do_section) Processing section "[homes]" [2016/07/21 11:47:15.960874, 3] ../source3/param/loadparm.c:1576(lp_add_ipc) adding IPC service [2016/07/21 11:47:15.960996, 3] ../source3/auth/user_util.c:403(map_username) Mapped user John Doe to john [2016/07/21 11:47:15.961081, 3] ../source3/auth/auth.c:178(auth_check_ntlm_password) check_ntlm_password: Checking password for unmapped user []\[John Doe]@[CLIENT] with the new password interface [2016/07/21 11:47:15.961144, 3] ../source3/auth/auth.c:181(auth_check_ntlm_password) check_ntlm_password: mapped user is: [SERVER]\[john]@[CLIENT] [2016/07/21 11:47:15.961698, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:15.962698, 3] ../source3/auth/auth.c:249(auth_check_ntlm_password) check_ntlm_password: sam authentication for user [John Doe] succeeded [2016/07/21 11:47:15.972750, 2] ../source3/auth/auth.c:305(auth_check_ntlm_password) check_ntlm_password: authentication for user [John Doe] -> [john] -> [john] succeeded [2016/07/21 11:47:15.972858, 3] ../auth/ntlmssp/ntlmssp_sign.c:547(ntlmssp_sign_init) NTLMSSP Sign/Seal - Initialising with flags: [2016/07/21 11:47:15.972906, 3] ../auth/ntlmssp/ntlmssp_util.c:34(debug_ntlmssp_flags) Got NTLMSSP neg_flags=0xe2088215 [2016/07/21 11:47:15.973353, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:15.974687, 3] ../source3/auth/token_util.c:547(finalize_local_nt_token) Failed to fetch domain sid for WORKGROUP [2016/07/21 11:47:15.974813, 3] ../source3/auth/token_util.c:579(finalize_local_nt_token) Failed to fetch domain sid for WORKGROUP [2016/07/21 11:47:15.975485, 3] ../source3/smbd/password.c:144(register_homes_share) Adding homes service for user 'john' using home directory: '/mnt/pool/homes/john' [2016/07/21 11:47:15.975671, 3] ../source3/param/loadparm.c:1527(lp_add_home) adding home's share [john] for user 'john' at '/mnt/pool/homes/%U' [2016/07/21 11:47:15.987285, 3] ../source3/lib/access.c:338(allow_access) Allowed connection from client.fritz.box (192.168.1.2) [2016/07/21 11:47:15.987560, 3] ../source3/smbd/service.c:614(make_connection_snum) Connect path is '/tmp' for service [IPC$] [2016/07/21 11:47:15.987680, 3] ../source3/smbd/vfs.c:113(vfs_init_default) Initialising default vfs hooks [2016/07/21 11:47:15.987743, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [/[Default VFS]/] [2016/07/21 11:47:15.988196, 3] ../source3/smbd/service.c:864(make_connection_snum) client (ipv4:192.168.1.2:58150) connect to service IPC$ initially as user john (uid=1101, gid=1102) (pid 11766) [2016/07/21 11:47:15.990497, 3] ../source3/smbd/msdfs.c:993(get_referred_path) get_referred_path: |john| in dfs path \SERVER\john is not a dfs root. [2016/07/21 11:47:15.994427, 3] ../source3/lib/access.c:338(allow_access) Allowed connection from client.fritz.box (192.168.1.2) [2016/07/21 11:47:15.994522, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:15.994822, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:15.995210, 3] ../source3/smbd/service.c:614(make_connection_snum) Connect path is '/mnt/pool/homes/john doe' for service [john] [2016/07/21 11:47:15.995296, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:15.995578, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:15.995850, 3] ../source3/smbd/vfs.c:113(vfs_init_default) Initialising default vfs hooks [2016/07/21 11:47:15.995912, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [/[Default VFS]/] [2016/07/21 11:47:15.995963, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [recycle] [2016/07/21 11:47:15.996611, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'recycle' loaded [2016/07/21 11:47:15.996689, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [streams_xattr] [2016/07/21 11:47:15.997214, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'streams_xattr' loaded [2016/07/21 11:47:15.997282, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [aio_pthread] [2016/07/21 11:47:15.997666, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'aio_pthread' loaded [2016/07/21 11:47:15.997733, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [zfsacl] [2016/07/21 11:47:15.998836, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'zfsacl' loaded [2016/07/21 11:47:15.998908, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [zfs_space] [2016/07/21 11:47:16.027946, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'zfs_space' loaded [2016/07/21 11:47:16.028250, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.028575, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.029099, 0] ../source3/smbd/service.c:800(make_connection_snum) canonicalize_connect_path failed for service john, path /mnt/pool/homes/john doe [2016/07/21 11:47:16.031050, 3] ../source3/lib/access.c:338(allow_access) Allowed connection from client.fritz.box (192.168.1.2) [2016/07/21 11:47:16.031151, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.031443, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.031805, 3] ../source3/smbd/service.c:614(make_connection_snum) Connect path is '/mnt/pool/homes/john doe' for service [john] [2016/07/21 11:47:16.031889, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.032161, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.032418, 3] ../source3/smbd/vfs.c:113(vfs_init_default) Initialising default vfs hooks [2016/07/21 11:47:16.032478, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [/[Default VFS]/] [2016/07/21 11:47:16.032530, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [recycle] [2016/07/21 11:47:16.032578, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [streams_xattr] [2016/07/21 11:47:16.032625, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [aio_pthread] [2016/07/21 11:47:16.032672, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [zfsacl] [2016/07/21 11:47:16.032719, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [zfs_space] [2016/07/21 11:47:16.032866, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.033154, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.033645, 0] ../source3/smbd/service.c:800(make_connection_snum) canonicalize_connect_path failed for service john, path /mnt/pool/homes/john doe [2016/07/21 11:47:16.035597, 3] ../source3/smbd/service.c:1140(close_cnum) client (ipv4:192.168.1.2:58150) closed connection to service IPC$ [2016/07/21 11:47:16.042251, 3] ../source3/smbd/server_exit.c:252(exit_server_common) Server exit (NT_STATUS_CONNECTION_RESET) [2016/07/21 11:47:16.048289, 3] ../source3/lib/access.c:338(allow_access) Allowed connection from client.fritz.box (192.168.1.2) [2016/07/21 11:47:16.048597, 3] ../source3/smbd/oplock.c:1309(init_oplocks) init_oplocks: initializing messages. [2016/07/21 11:47:16.048770, 3] ../source3/smbd/process.c:1880(process_smb) Transaction 0 of length 178 (0 toread) [2016/07/21 11:47:16.049071, 3] ../source3/smbd/smb2_negprot.c:269(smbd_smb2_request_process_negprot) Selected protocol SMB3_11 [2016/07/21 11:47:16.051154, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'gssapi_spnego' registered [2016/07/21 11:47:16.051234, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'gssapi_krb5' registered [2016/07/21 11:47:16.051284, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'gssapi_krb5_sasl' registered [2016/07/21 11:47:16.051333, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'spnego' registered [2016/07/21 11:47:16.051386, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'schannel' registered [2016/07/21 11:47:16.051434, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'naclrpc_as_system' registered [2016/07/21 11:47:16.051482, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'sasl-EXTERNAL' registered [2016/07/21 11:47:16.051530, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'ntlmssp' registered [2016/07/21 11:47:16.051578, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'http_basic' registered [2016/07/21 11:47:16.051626, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'http_ntlm' registered [2016/07/21 11:47:16.051674, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'krb5' registered [2016/07/21 11:47:16.051721, 3] ../auth/gensec/gensec_start.c:899(gensec_register) GENSEC backend 'fake_gssapi_krb5' registered [2016/07/21 11:47:16.055424, 3] ../auth/ntlmssp/ntlmssp_util.c:34(debug_ntlmssp_flags) Got NTLMSSP neg_flags=0xe2088297 [2016/07/21 11:47:16.057906, 3] ../auth/ntlmssp/ntlmssp_server.c:359(ntlmssp_server_preauth) Got user=[John Doe] domain=[] workstation=[CLIENT] len1=24 len2=324 [2016/07/21 11:47:16.057999, 3] ../source3/param/loadparm.c:3730(lp_load_ex) lp_load_ex: refreshing parameters [2016/07/21 11:47:16.058247, 3] ../source3/param/loadparm.c:544(init_globals) Initialising global parameters [2016/07/21 11:47:16.058628, 3] ../source3/param/loadparm.c:2659(lp_do_section) Processing section "[global]" [2016/07/21 11:47:16.060778, 2] ../source3/param/loadparm.c:2676(lp_do_section) Processing section "[homes]" [2016/07/21 11:47:16.062383, 3] ../source3/param/loadparm.c:1576(lp_add_ipc) adding IPC service [2016/07/21 11:47:16.062501, 3] ../source3/auth/user_util.c:403(map_username) Mapped user John Doe to john [2016/07/21 11:47:16.062584, 3] ../source3/auth/auth.c:178(auth_check_ntlm_password) check_ntlm_password: Checking password for unmapped user []\[John Doe]@[CLIENT] with the new password interface [2016/07/21 11:47:16.062651, 3] ../source3/auth/auth.c:181(auth_check_ntlm_password) check_ntlm_password: mapped user is: [SERVER]\[john]@[CLIENT] [2016/07/21 11:47:16.063177, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.064166, 3] ../source3/auth/auth.c:249(auth_check_ntlm_password) check_ntlm_password: sam authentication for user [John Doe] succeeded [2016/07/21 11:47:16.073886, 2] ../source3/auth/auth.c:305(auth_check_ntlm_password) check_ntlm_password: authentication for user [John Doe] -> [john] -> [john] succeeded [2016/07/21 11:47:16.073994, 3] ../auth/ntlmssp/ntlmssp_sign.c:547(ntlmssp_sign_init) NTLMSSP Sign/Seal - Initialising with flags: [2016/07/21 11:47:16.074041, 3] ../auth/ntlmssp/ntlmssp_util.c:34(debug_ntlmssp_flags) Got NTLMSSP neg_flags=0xe2088215 [2016/07/21 11:47:16.074485, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.075817, 3] ../source3/auth/token_util.c:547(finalize_local_nt_token) Failed to fetch domain sid for WORKGROUP [2016/07/21 11:47:16.075944, 3] ../source3/auth/token_util.c:579(finalize_local_nt_token) Failed to fetch domain sid for WORKGROUP [2016/07/21 11:47:16.076642, 3] ../source3/smbd/password.c:144(register_homes_share) Adding homes service for user 'john' using home directory: '/mnt/pool/homes/john' [2016/07/21 11:47:16.076829, 3] ../source3/param/loadparm.c:1527(lp_add_home) adding home's share [john] for user 'john' at '/mnt/pool/homes/%U' [2016/07/21 11:47:16.087693, 3] ../source3/lib/access.c:338(allow_access) Allowed connection from client.fritz.box (192.168.1.2) [2016/07/21 11:47:16.087764, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.087958, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.088206, 3] ../source3/smbd/service.c:614(make_connection_snum) Connect path is '/mnt/pool/homes/john doe' for service [john] [2016/07/21 11:47:16.088259, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.088433, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.088595, 3] ../source3/smbd/vfs.c:113(vfs_init_default) Initialising default vfs hooks [2016/07/21 11:47:16.088638, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [/[Default VFS]/] [2016/07/21 11:47:16.088670, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [recycle] [2016/07/21 11:47:16.089060, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'recycle' loaded [2016/07/21 11:47:16.089108, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [streams_xattr] [2016/07/21 11:47:16.089432, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'streams_xattr' loaded [2016/07/21 11:47:16.089474, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [aio_pthread] [2016/07/21 11:47:16.089700, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'aio_pthread' loaded [2016/07/21 11:47:16.089741, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [zfsacl] [2016/07/21 11:47:16.090400, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'zfsacl' loaded [2016/07/21 11:47:16.090447, 3] ../source3/smbd/vfs.c:139(vfs_init_custom) Initialising custom vfs hooks from [zfs_space] [2016/07/21 11:47:16.107968, 2] ../lib/util/modules.c:196(do_smb_load_module) Module 'zfs_space' loaded [2016/07/21 11:47:16.108227, 3] ../libcli/security/dom_sid.c:209(dom_sid_parse_endp) string_to_sid: SID john is not in a valid format [2016/07/21 11:47:16.108425, 3] ../source3/passdb/lookup_sid.c:1645(get_primary_group_sid) Forcing Primary Group to 'Domain Users' for john [2016/07/21 11:47:16.108740, 0] ../source3/smbd/service.c:800(make_connection_snum) canonicalize_connect_path failed for service john, path /mnt/pool/homes/john doe [2016/07/21 11:47:26.665107, 3] ../source3/smbd/server_exit.c:252(exit_server_common) Server exit (NT_STATUS_CONNECTION_RESET)
ln -s /mnt/pool/homes/john /mnt/pool/homes/john\ doe
Best regards,
dP
