if it helps i have installed truenas on an optiplex 7010 i5 16gb ram. oh and there are 2 dents on the side of the case. dont worry its the door pannel. i am running truenas on 2 different machines. the one in question you have the stats. oh and it is core. so i have been running both around the same amount of time. around 2 months. both servers i can access the gui and see and change permissions on truenas within the gui. server 1 has just stoped sharring smb with my computer i use to access. server 2 i have no issues. why is this and how to fix it. server 1 can be accessed via gui but i cannot add or remove files in samba? server 2 everything is working fine? both set up exactly the same. only difference is a different motherboard and processor on server 2.
