SOLVED Samba ACL
Tom7320
Hi there!
With samba 4 I like the way to configure the permissions of my shares just by using Windows Explorer. But there is one thing I noticed witch I do not understand. I created a standard cifs share. Then in Windows Explorer I moved to properties -> security. That is what I see:
What is the meaning of the "unknown user" with the red question mark? What is the reason for that? How can I fix that?
THX a lot!
Regards,
Thorsten
SweetAndLow
Sweet'NASty
Is your dataset configured to use Unix permissions or windows permissions?
vikingboy
I see the same user and just delete it when I create my users etc.
alexg
Tom7320
It's an HP ProLiant MicroServer N54L running FreeNAS 9.3 stable.
[root@freenas] ~# cat /usr/local/etc/smb4.conf
[global]
    server max protocol = SMB3
    encrypt passwords = yes
    dns proxy = no
    strict locking = no
    oplocks = yes
    deadtime = 15
    max log size = 51200
    max open files = 231455
    load printers = no
    printing = bsd
    printcap name = /dev/null
    disable spoolss = yes
    getwd cache = yes
    guest account = nobody
    map to guest = Bad User
    obey pam restrictions = yes
    directory name cache size = 0
    kernel change notify = no
    ea support = yes
    store dos attributes = yes
    hostname lookups = yes
    time server = yes
    acl allow execute always = true
    acl check permissions = true
    dos filemode = yes
    domain logons = no
    local master = yes
    idmap config *: backend = tdb
    server role = standalone
    netbios name = FREENAS-CIFS
    workgroup = WORKGROUP
    security = user
    pid directory = /var/run/samba
    smb passwd file = /var/etc/private/smbpasswd
    private dir = /var/etc/private
    create mask = 0666
    directory mask = 0777
    client ntlmv2 auth = yes
    dos charset = CP437
    unix charset = UTF-8
    log level = 1
[AnA]
    path = /mnt/vol1/AnA
    comment = AnästhesieAgentur GmbH
    printable = no
    veto files = /.snapshot/.windows/.mac/.zfs/
    writeable = yes
    browseable = yes
    recycle:repository = .recycle/%U
    recycle:keeptree = yes
    recycle:versions = yes
    recycle:touch = yes
    recycle:directory_mode = 0777
    recycle:subdir_mode = 0700
    vfs objects = zfsacl aio_pthread streams_xattr
    hide dot files = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
    zfsacl:acesort = dontcare
[Archiv]
    path = /mnt/vol1/Archiv
    comment = Archive files
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[BTSync]
    path = /mnt/vol1/BTSync
    comment = BTSync
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Backup]
    path = /mnt/vol1/Backup
    comment = Backup files
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Christina]
    path = /mnt/vol1/Christina
    comment = Christina's own share
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Docs]
    path = /mnt/vol1/Docs
    comment = All kind of docs
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[ISO]
    path = /mnt/vol1/ISO
    comment = ISO Images
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Multimedia]
    path = /mnt/vol1/Multimedia
    comment = Audio and video share
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Public]
    path = /mnt/vol1/Public
    comment = Public share
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Software]
    path = /mnt/vol1/Software
    comment = Software installer
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Test]
    path = /mnt/vol1/Test
    comment = For testing purposes only
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[Thorsten]
    path = /mnt/vol1/Thorsten
    comment = Thorsten's own share
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[USB]
    path = /mnt/vol1/USB
    comment = My daily work files
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[iTunes]
    path = /mnt/vol1/iTunes
    comment = iTunes share
    printable = no
    writeable = yes
    browseable = yes
    recycle:touch = yes
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
[root@freenas] ~#
