I started getting complaint from freenas about a corrupted file on boot device. The file is not critical, it's /usr/local/lib/libbiconv.a. I see it comes from iconv-2.0_4 package. But why doesn't the "pkg list" command show iconv being installed? Is it due it being installed withing "bootstrap", prior to using pkg?
Is it safe to do pkg install iconv, and let it overwrite the file, or should I download the iconv binary package and extract the file from there?
Thanks,
ikke
[root@freeknas] ~# zpool status -v freenas-boot
pool: freenas-boot
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 216K in 0h2m with 1 errors on Sun Feb 22 03:47:12 2015
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 1
mirror-0 ONLINE 0 0 2
gptid/1f08078c-9e3c-11e4-a2fb-c86000887167 ONLINE 0 0 13
gptid/1f98e245-9e3c-11e4-a2fb-c86000887167 ONLINE 0 0 2
//usr/local/lib/libbiconv.a
[root@freeknas] ~# pkg which /usr/local/lib/libbiconv.a
/usr/local/lib/libbiconv.a was installed by package iconv-2.0_4
[root@freeknas] ~# pkg --list|grep iconv
[root@freeknas] ~#
pool: freenas-boot
state: ONLINE
[root@freeknas] ~#
Thanks,
ikke
