Does Truenas Scale support the following NICs?
Truenas sees the 5G adapter, but only works at 1Gb/s. Truenas doesn't see the 10G adapter at all. There is a driver from Sabrent, but if I install it manually then this driver will disappear on the next Truenas update. Is it possible to include this driver into Truenas build out?
Thanks,
James
SABRENT USB Type-A or Type-C to 5-Gigabit Ethernet Adapter [10/100/1000/2500/5000 Mbps] (NT-SS5G)
SABRENT Thunderbolt 3 to 10 Gbps RJ-45 Ethernet Adapter (TH-S3EA)
Thanks,
James
