JohnDoe123
 - Dec 10, 2016
Dear all
appreciate your thoughts on the matter below -
I'm running FreeNAS-9.10.2-U6 (561f0d7a1) with a few jails. Up until recently, sabnzb was running in one jail just fine (V1.2.3 I think - I did't track versioning that closely). All of a sudden, http basic auth was requested when accessing the daemon which was odd since I did not configure it like that.
When investigating, I found sabnzb to be running more oddly. Final conclusion is that I deleted the jail and am trying to reinstall ever since, few times trying the available plugins via web GUI, few times by downloading .pbi (both, recent and previous version) from download.freenas.org and adding it as custom jail. All attempts lead to same result:
I was able to successfully bring up sabnzbd manually via command line, omitting the --daemon, -f, --pidfile parameters, giving me the following:
When invoking will full parameter set, sabnzbd did not come up but bring same error message like above.
Googling around wasn't much helpful, I came across one thread on sab's forums but despite upgrading pip - w/o effect here - there wasn't much guidance.
Worth mentioning that I was successful in installing sabnzbd in jail on my Freenas11 test machine.
Any thoughts?
Regards
JD
root@customplugin_1:/ # service sabnzbd onestart Starting sabnzbd. /usr/local/etc/rc.d/sabnzbd: WARNING: failed to start sabnzbd
root@customplugin_1:/usr/local/etc/rc.d # /usr/pbi/sabnzbd-amd64/bin/python2.7 /usr/pbi/sabnzbd-amd64/bin/SABnzbd.py -s 0.0.0.0 /usr/pbi/sabnzbd-amd64/lib/python2.7/site-packages/cryptography/hazmat/bindings/__pycache__/_Cryptography_cffi_d62b3d91x972e1c0b.c:187:10: fatal error: 'CoreFoundation/CoreFoundation.h' file not found #include <CoreFoundation/CoreFoundation.h>
Any thoughts?
Regards
JD
