The following error kept showing when I started sabnzbd
When I went through the python code I noticed that this error only became active in 2 places in sabnzbd.py.
First was the version of python lower then 3.7 and the following was on importing libraries. I could import all libs except one
So checked if py38-importlib-resources: 5.4.0_1 was installed and it was not. After installing it sabnzbd could start successfully. Not sure since this is a plugin where to report this bug.
Not all required Python modules are available, please check requirements.txt
Missing module:
You can read more at: https://sabnzbd.org/wiki/installation/install-off-modules
If you still experience problems, remove all .pyc files in this folder and subfolders
>>> import guessit
File "/usr/local/lib/python3.8/site-packages/guessit/rules/properties/website.py", line 7, in <module>
from importlib.resources import files # @UnresolvedImport
ImportError: cannot import name 'files' from 'importlib.resources' (/usr/local/lib/python3.8/importlib/resources.py)
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.8/site-packages/guessit/__init__.py", line 8, in <module>
from .api import guessit, GuessItApi
File "/usr/local/lib/python3.8/site-packages/guessit/api.py", line 17, in <module>
from .rules import rebulk_builder
File "/usr/local/lib/python3.8/site-packages/guessit/rules/__init__.py", line 17, in <module>
from .properties.website import website
File "/usr/local/lib/python3.8/site-packages/guessit/rules/properties/website.py", line 9, in <module>
from importlib_resources import files # @UnresolvedImport
ModuleNotFoundError: No module named 'importlib_resources'
