SABnzbd Folder Config Wont Save
exactrawr
Hi all,
I am trying to configure SABnzbd inside FreeNAS 9.1.1. I have set up all of my mountpoints and jails correctly according to this guide: http://mybroadband.co.za/vb/showthr...-SABnzbd-Sickbeard-and-Headphones-Setup-Guide
My problem is: When I try and point SAB to the temp/complete/watch folders in the web GUI after I hit save and try and configure something else it goes back to the default folders it started with? Oddly enough I can configure the Categories tab and it saves no problem.
I have set the owner/group of the Jail/plugins to my personal user. Not sure if that helps
Any support on this issue would be greatly appreciated
Thanks!
exactrawr
Im thinking its something todo with the folder permissions that are currently set up? Thinking this because I can save everything but where downloads are watched/incomplete/complete. I have SSH'ed into my jail directory and changed the octal value to match the one in Sab. Still no luck there.
How should I have my folders set up?
Im getting the samething with Couch Potato. I think im missing something when it's coming to folder permissions. Any ideas?
I manged to get the config to save. Was a octal error. Now im getting
2013-10-02 22:42:50,610 ERROR: download_dir directory: /SABNZBD/Incomplete error accessing
2013-10-02 22:40:55,136 ERROR: download_dir directory: /SABNZBD/Incomplete error accessing
2013-10-02 22:26:07,472 ERROR: download_dir directory: /SABNZBD error accessing
2013-10-02 22:19:15,616 ERROR: download_dir directory: /SABNZBD error accessing
Getting so close to solving this. Any ideas for a workaround on the above?
Here is the bug report anyway:
https://bugs.freenas.org/issues/3240
david kennedy
Who "owns" the directory "/SABNZBD " and which account is your sab running under? They should be equal as the default permissions are usually 755 (RWXRXRX)
