Sabnzbd broken
STREBLO
I'm on a new clean install of 9.10. Fresh install of Sabnzbd seems to be broken, it wont start i've tried restarting it a few times as well as restarting the trail and even restarting the server.
I'm getting the error:
[freeadmin.navtree:629] An error occurred while unserializing from http://192.168.0.142/plugins/sabnzbd/4/_s/treemenu: No JSON object could be decoded
maglin
try building a standard jail and installing sabnzbd through portsnap. You can google fresh ports and find all the info you need to use portsnap. It allows for easier updates.
portsnap fetch
portsnap extract
cd /usr/ports/news/sabnzbdplus/ && make install clean
That is from memory but should get you going. Also ensure you are in the jail for this and not FreeNAS.
STREBLO
portsnap fetch
portsnap extract
Yea, I know how to use FreeBSD ports. What matters is that the plugin is broken.
Joshua Parker Ruehlig
just to clarify, the plugin (pbi) itself is fine, your jail needs working networking to communicate with the freenaa webui for everything to work as expected.
STREBLO
My jail has networking, I can ping out and it's setup the same as all my other jails. It was working before setup the same on 9.3.
Just to clarify.
I meant that the pbi itself works, but not in your particular case. so other plugins work as expected on your system currently?
STREBLO
Yessir. Sickrage, Emby, Couchpotato etc.... All fine.
STREBLO
Ok, i've now noticed Couchpotato is throwing errors too, however, it appears to still be functioning.
Apr 15 18:07:09 Lilan manage.py: [freeadmin.navtree:575] Couldn't retrieve http://192.168.0.142/plugins/couchpotato/4/_s/treemenu: timed out
NigelNoFriends
@STREBLO Any progress on the broken plug-ins. Seems to be a lot of people having same issue in on update to 9-10-Stable too.
STREBLO
