SABnzb Permissions Issues
protonus
So I have installed Truenas Scale and managed to get my Windows VM with PCI passthrough for the weather station working. I moved all my movies from my windows PC to Truenas and installed Plex (working), Sonarr (working), Radarr (working) and SABnzb(permissions issue), I have a problem with the permissions of SABnzb and cannot get them to work correctly. When I type in ls- l in the shell of SABnzb I get:
-rw-r--r-- 1 kah kah 1584 Mar 17 13:33 COPYRIGHT.txt
drwxr-xr-x 2 kah kah 53 Mar 17 16:30 email
-rw-r--r-- 1 kah kah 17990 Mar 17 13:33 GPL2.txt
-rw-r--r-- 1 kah kah 35147 Mar 17 13:33 GPL3.txt
drwxr-xr-x 2 kah kah 13 Mar 17 16:30 icons
-rw-r--r-- 1 kah kah 4876 Mar 17 13:33 INSTALL.txt
drwxr-xr-x 5 kah kah 5 Mar 17 16:30 interfaces
-rw-r--r-- 1 kah kah 2918 Mar 17 13:33 ISSUES.txt
drwxr-xr-x 2 kah kah 9 Mar 17 16:30 licenses
-rw-r--r-- 1 kah kah 794 Mar 17 13:33 LICENSE.txt
drwxr-xr-x 2 kah kah 3 Mar 17 16:30 linux
drwxr-xr-x 19 kah kah 19 Mar 17 16:30 locale
-rw-r--r-- 1 kah kah 295 Mar 17 13:33 PKG-INFO
drwxr-xr-x 5 kah kah 5 Mar 17 16:30 po
-rw-r--r-- 1 kah kah 3054 Mar 17 13:33 README.mkd
-rw-r--r-- 1 kah kah 1402 Mar 17 13:33 requirements.txt
drwxr-xr-x 3 kah kah 46 Mar 17 16:30 sabnzbd
-rw-r--r-- 1 root root 6639 Mar 17 16:29 sabnzbd.ini
-rwxr-xr-x 1 kah kah 63785 Mar 17 13:33 SABnzbd.py
drwxr-xr-x 2 kah kah 6 Mar 17 16:30 scripts
drwxr-xr-x 4 kah kah 33 Mar 17 16:30 tests
drwxr-xr-x 2 kah kah 6 Mar 17 16:30 tools
However, these files are not in my samba share when I look in windows, so a bit confused there.
I have a samba share where I can access all my movies from another Win10 machine and I can see the SABnzb folder I created and that is where I installed the app (using the HostPath option). I downloaded it from the TrueCharts catalogue.
I have tried to make that share the owner of user "kah" as stated in the ls- l command I did. Apologies but I do not know much about Linux (learning) and I do like Truenas and would like to keep it, lots of things I can do with it.
I do know it is a permissions issue and I do now know how to fix it for it to work with the version from TrueCharts Catalogue. I also tried with the docker image from "linuxserver/sabnzbd" and I got the same issue. I have search the whole weekend and no results from my online shearches.
protonus
So I have figured it out for myself. I just removed the ACL permissions and it all seemed to work, SABnzb downloads and Sonarr/Radarr work as well and Plex too. Everything moved into the right folders, however on to my next issue. My TV doesn't see the plex server but I can access it on my browser. But in case anyone has issues, try like I did and remove the ACL permission. The user is a new user I created but has root privileges in that folder.
