SABnzb Permission error
Jeff Lamer
After recent update of FreeNAS I am now getting the following error in SABnzb
Cannot change permissions of /mnt/media/downloads/sabnzbd/incomplete
Jeff
Joshua Parker Ruehlig
what do you get with the following run in the sabnzbd jail?
ls -l /mnt/media/downloads/sabnzbd
ls -l /mnt/media/downloads/sabnzbd/incomplete
Jeff Lamer
Hey Joshua,
This was the response;
It's Odd now, The completed files from SABnzb are not being moved to the media/video/movie folder. They are just staying in completed. From FreeNAS ui Sabnzb is giving me an error when I try to update.
error: umount: /mnt/cormadVolume/jails/sabnzbd_1/mnt/media: not a file system root directory
Hey Joshua,
Are the downloads shown to be in the category 'movie'? Is your categories tab correct?
You are trying to update the sabnzbd plugin? What version are you on? I haven't released an update in a really long time.
Jeff Lamer
I will do my testing today as I just reset FreeNAS, Tabs are correct as I haven't changed them from the start and it was working correctly.
Sorry about the confusion, I meant to say CouchPotato not Sabnzb in the upper post. CouchPotato won't update from the FreeNAS GUI
Jeff
Jeff
OK, as for the update, you might want to check your Jails > Storage tab and adjust things there.
Jeff Lamer
Jeff Lamer
Ok When I updated I received the same error : Cannot change permissions of /mnt/media/downloads/sabnzbd/incomplete
When I check permissions they are set to
user:root
group: wheel
Do I change this to media:media ?
I also noted that my other jails
sabnzb_1, emby_1 and htpc-manager_1 are all
user:root
group: wheel
Jeff
user:root
group: wheel
user:root
group: wheel
Jeff
never change the permissions of your jail dataset(s), that will break the jail.
assuming /mnt/media is actually a dataset mounted into the jail, then changing ownership to media:media should allow sabnzbd to write to that location.
Jeff Lamer
Ok, A bit confused as per usual. By jail dataset(s) you are referring to jails/sabnzb_1 under the Storage tab ? these are all set to root:wheel. Under the same tab (Storage) I also have media, it was set to root:wheel but I changed it last night to media:media. Was that a mistake? Couch potato did work correctly last night and did a complete movie.
Jeff
Jeff
yes that's the jail dataset. I wasn't sure what you were intending to change yesterday but you did it correctly
Jeff Lamer
Ok,just to double check.... the jail/sabnzb_1 should be root:wheel and I should NEVER change those.
never change that for any of your jail datasets
Top Bottom
