jgreco
Resident Grinch
- May 29, 2011
Probably not quiet, but really it is hard to tell. The ethernet switches generate a dull roar and their redundant power supplies are very noisy. Hard to tell in a rackful of gear how noisy one bit of gear is.
I believe that all the fans except for the ones in the power supply are PWM driven. Typically the fans are incredibly noisy if they're fully revved, but if you configure the BMC to reduce speeds, you reduce both noise and energy consumption. Still, cooling a dense drive array in a small space is a challenge. I've written on the topic of the Supermicro and Norco 4U's in the past. They're going to need forced air. Period.
You can of course use an alternative chassis of some sort, but then you're probably not going to wind up with a nearly-free SAS expander as part of a backplane and nice drive trays for your drives. So it's damned-if-you-do, damned-if-you-dont.
