Martin Aspeli
- Jan 13, 2016
I am migrating a custom rolled
I'd like to ping a
I can see that when the task is running, it generates an rclone config in
rclone
backup solution with the now-built-in FreeNAS "cloud sync" task (which uses rclone under the hood), to push backups to Backblaze B2.I'd like to ping a
healthchecks.io
URL when the backup completes to get alerts in case there is a problem with FreeNAS itself or my network or Backblaze. That was easily done with curl in an old cron job, but I can't find an easy way to do it using FreeNAS. Is there any ability to trigger a script or command when the cloud sync is done?I can see that when the task is running, it generates an rclone config in
/tmp
and runs rclone by itself. What actually manages the cloud sync tasks?
