Ruined my network settings
OmriA
I tried to change my network settings to a static IP. Unfortunately, I managed to get my nas unreachable.
I used guides on the internet but nothing looks exactly like what I see in my Truenas scale.
Can you help me reconfigure my IP to an IPv4 non DHCP?
I'm totally lost...
Patrick M. Hausen
The console menu offers an option to chose the network settings.
OmriA
I know, but I don't know what to type, I'm new to this and I can't find a guide (the options it gives me after I choose "1", looks different than the guides)
Patrick M. Hausen
Mine says "hit enter to edit a network interface" after I select "1". So just do that and follow the menu guidance ...
Your TrueNAS seems to have an IP address. Namely 10.0.0.40 - cant't you ping that? What's the IP address of the PC you want to use to connect to the NAS?
OmriA
I managed to reset it, my web GUI is back, I want my IP to be 10.0.0.40, IPv4, non-DHCP.
Now it's 10.0.0.12 (pic. 1), should I edit the existing IP (pic. 2) or should I create a new one (pic. 3)?
