I have a few rsync tasks setup, and I am struggling with the Extra options field. First I added this, for logging:
That works as intended. I then tried putting this in the Extra options field, to exclude mounted folders:
Also works, all instances of Folder1 and Folder2 are skipped.
So, finally, i´d like my Extra options field to contain all of that, like this:
Now there´s trouble. At first, rsync would´nt even run, but gave me an error:
After trying back and forth with putting commands in different orders, it suddenly works. Or well, rsync runs and correct folders are skipped. But nothing is logged.
Extra options now looks like this (added comma):
Am i doing somthing wrong?
--progress --log-file=/var/log/rsync.log
--exclude=Folder1 --exclude=Folder2
--progress --log-file=/var/log/rsync.log --exclude=Folder1 --exclude=Folder2
2017/07/06 10:01:13 [8261] rsync: connection unexpectedly closed (0 bytes received so far) [sender] 2017/07/06 10:01:13 [8261] rsync error: error in rsync protocol data stream (code 12) at io.c(226) [sender=3.1.2]
--progress --log-file=/var/log/rsync.log, --exclude=Folder1 --exclude=Folder2
