Long time user of freenas here. First time having to post for information.
Can not seem to get rsync to work on TrueNAS core 12. This is from any *nix box to TrueNAS using rsync named module.
I have 2 FreeNAS-11.3-U5 machines running fine. I set up a new FreeNAS-11.3-U5. Confirmed everything hardware wise worked. Set everything up like the other 2 boxes. I then did the upgrade to TrueNAS core. I tried to use rsync from Ubuntu 18.04, Linux Mint, and FreeBSD 12. I get the same error of:
I triple checked all settings were the same between FreeNAS and TrueNAS.
I reinstalled from scratch FreeNAS-11.3-U5 onto it and rsync works fine. Is this a bug I need to file or did something change that I am unaware of?
rsync command that works on FreeNAS and not on TrueNAS:
Machine in question (even though I dodn't think it matters)
Dell r720
H310 mini (IT mode)
7 SAS drives in raidz2
rsync: connection unexpectedly closed (0 bytes received so far) [sender] rsync error: error in rsync protocol data stream (code 12) at io.c(235) [sender=3.1.2]
rsync -az --no-g --no-perms --omit-dir-times -O --exclude-from '/home/XXXX/rsync_excludeme.txt' / nas003.XXXXXX.XXX::vhost004
Dell r720
H310 mini (IT mode)
