Zaret
- Mar 2, 2019
Hey together,
could it be that the private key for an rsync over ssh must be named id_rsa?
Or how i can use keys with other names?
The Story:
today i wanted to setup an rsync task over ssh.
I created a private and public rsa key with a custom name, transfered the public key to the other server and enter it into the authorizes_keys file.
I used an config file for the mapping between IdentityFile and host and it worked like a charm.
While during the creation of the task i get the error :
Even if i add the keys in "SSH Connections" it doesn't work.
With despair i renamed the key to id_rsa and suddenly it worked there to.
There is nothing in the Truenas docs about it.
Is this an unnamed rule or how i'm able to use different named keys?
Thanks
The Story:
In order to use rsync over SSH you need a user with a private key (DSA/ECDSA/RSA) set up in home dir.
Thanks
