I'm getting kernel panics on the detination machine when running my scheduled daily rsync push task. Source machine is FreeNAS 11.3-U1. Destination machine is FreeBSD-12.1.  The problem is quite repeatable. I suspect it happens on the same file every time, but determining what file is causing the problem has been elusive.
To determine what file(s) is(are) causing the issue, I'd like to run the rsync command from a command line, adding -v to identify what file is being transferred when the panic occurs. Then, I can pursue the underlying cause of the panic on the receiving end. But to do that, I need to know the options being passed on the command line. I tried starting the task, then using 'ps' in a terminal session to capture the command line, but the command line is so long that it gets truncated in the output from ps.
So I'd either like to know how to determine what FreeNAS is going to issue as a command, or at least have a way to make the log file more verbose to identify what files are being transferred.
