I was running a test to make sure rsync would transfer with the correct permissions. So I setup a test folder that I could play with but a misconfiguration cause the server with the data to delete all its data.
Edit: If it's ZFS, it's gone. If its UFS there are some program you can buy to do data recovery. But I wouldn't hold my breath on a high degree of success.
Unfortunately there are no recovery tools to run on ZFS.. If the data is gone it'll be truly gone.. The only thing I can think of is if you had used CIFS shares and files got moved to the recycling bin on pool? What command did you run?
I used the web interface to setup the rsync. Its funny. I was going to used rsync to sync these two servers together so they would be each others backed up. Now there is nothing.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
