IonutZ
- Aug 17, 2014
Hey there, I have 2 FreeNAS servers on the network and I'm attempting to backup a bunch of files from one to the other. The initial backup is somewhere around 100GB. The connection is somewhere around 20Mbps because it's over the internet. It's been around 4 days now since I've set up the backup, and I see almost the entire folder structure that's on the other server, but no files. It seems every folder has a .~tmp~ folder and that is full of files, but NONE of the folders actually have files in them.
1. Is this normal? Will the files from the .~tmp~ folder be moved to the parent folder?
2. If this is not normal, is it because I have rsync running every minute of every hour? I just want everything to be backed up as soon as possible after the system is nominal.
Your help is much appreciated.
