Thousandbuckle
- Jul 9, 2014
Hello all, I have setup my first RSYNC in FreeNAS 9.3 to sync between 2 FreeNAS boxes on the local LAN.
I have setup an RSYNC Task using the RSYNC module setup on the server and client. On the client side I have Recursive, Times, Compress, and Delay Updates enabled.
The RSYCN task started and is creating the folder structure on the target backup server but I dont see any files in the folders. The total dataset I am RSYNCing is 10.5TB and I see 1.5 TB in the target data set for the backup but dont see any files? How can I have 1.5TB of data but no files?
Second question is how can I see the overall progress of the RSYNC to see either amount of data copied, time left, current file being copied, etc.?
