Rsync - a runaway train
Hyperion
Hi
Been setting up all the rsync’s to my backup server I think I will need.
Tested most on VM.
But of course the one I went live with was a 1.2TB file.
Is there anyway I can stop a rsync?
Thanks
fracai
Kill the process. What os is the other end?
Hyperion
Its the same deal : FreeNAS-9.2.1.5-RELEASE-x64 (80c1d35)
I just want it to stop.....
fracai
Open a command prompt, type "killall rsync". If it reports nothing owned by you, type "su", enter the root password at the prompt, and try again.
Hyperion
Cannot believe this, it finished just as I was about to type, kill.
6 Hours for 1.2 TB
Thanks for the tip.
