Rollback Extend Disk
SuperSavio
i everyone,
I have a problem with a Pool after extending with another HardDrive.
Nas Mini Server HP with 4 Slot for HDD, i mounted only 3HD.
one of this, Pool Media_4TB = HD WD RED 4TB, I have extended this with another same disk ( to have an 8TB pool ) and the operation finished successfully.
Today the Pool is in an UNKNOWN state and I only see the first disk . The new disk doesn't work, it's dead.
On the new disk I have not loaded anything, no files for this I do not worries, but i can't mount the old Disk and continue work with this.
I have try with ZFS MOUNT but i have this error "dataset does not exist"
How i can fix?
First of all...
dev/ada1 is not the same as /dev/ada1 (unless you first cd to /)
Second...
zfs mount has little to do with what you seem to need right now.
What would be helpful to see is the output from zpool status -v Media_4TB
SuperSavio
Hi sretalla,
if i use zsh mount / dev / ada1 i will received this output
cannot open '/ dev / ada1': leading slash in name
after searching on google, haved found a suggestion of a user that tell removed the first slash. i tried without / before folder dev with the result of the previous post.
This is output of zpool status -v Media_4TB and zpool status -v
root@freenas[~]# zpool status -v Media_4TB
cannot open 'Media_4TB': no such pool
  pool: Data
 state: ONLINE
  scan: scrub repaired 0 in 0 days 01:43:19 with 0 errors on Sun Feb  6 01:43:20 2022
        NAME                                          STATE     READ WRITE CKSUM
        Data                                          ONLINE       0     0     0
          gptid/a7bd1b72-aa86-11eb-bdcc-a0b3cce3fb7a  ONLINE       0     0     0
errors: No known data errors
  pool: HD2
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:43:27 with 0 errors on Sun Jan  9 00:43:29 2022
        HD2                                           ONLINE       0     0     0
          gptid/61c91a70-6d40-11ea-b346-a0b3cce3fb7a  ONLINE       0     0     0
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:04:06 with 0 errors on Wed Feb  2 03:49:06 2022
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
the system seems not to see :(
Maybe you meant zfs mount... in any case, I already said that command has little to do with solving your problem, so I won't address its correct use here.
If the pool is now missing, we should look at zpool import to se what might still be there...
SuperSavio
yes, I was referring to zfs.
this is output of zpool import
root@freenas[~]# zpool import
   pool: Media_4TB
  state: UNAVAIL
 status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://illumos.org/msg/ZFS-8000-3C
        Media_4TB                                     UNAVAIL  insufficient replicas
          gptid/3525b579-3c08-11eb-95a5-a0b3cce3fb7a  ONLINE
          13924785740365534829                        UNAVAIL  cannot open
@sretalla's already mentioned that neither this, nor anything like this, is a reasonable command to be using, but also be aware that the spaces you're adding are going to break things. / dev / ada1 is not the same thing at all as /dev/ada1.
But your more fundamental problem appears to be that you've put a server into production with no understanding of how ZFS works. As a result, you've made some decisions that are quite probably going to be fatal to your data. The first problem was setting up single-disk pools, which means that the failure of any one of those disks means the data on that disk will be lost. The second problem was extending one of those pools by adding another disk to it--now you've created a striped pool, meaning that failure of either one of those disks will result in loss of all data on the pool. The third problem is that (it appears, based on your statement that there are no files on the new disk, from which I infer that you just added it) you put a disk into production without doing any kind of burn-in testing on it.
Your bottom line is that if you can't get the newly-added disk online, your data on that pool (all of it, not just whatever would have been on the new disk) is gone.
SuperSavio
spaces have been added by copy and paste of the web console. As you can see in the screens of the first post, the command is without spaces. The first attempt was zsf mount /dev/ada1 getting the slash error, searching the web a user said to remove it. The second attempt was with zsf mount dev/ada1 getting the other error. But let's not talk about this anymore because we have ascertained that it is not useful for resolution.
Now i have connect the HD "died" from USB and the system see it. I read somewhere, I can't find the thread, a command to scan for devices and associate them with its pool.Can this help me get the pool online and try to recover the data?
Yet another reason not to use the web console. Seriously, don't. Use SSH instead. With Windows 10, you don't even need to install anything, just run ssh user@host from PowerShell.
If the disk is online, the pool should import. What's the output of zpool import?
SuperSavio
this
   pool: Media_4TB
  state: UNAVAIL
UPDATE:
From alert:
CRITICAL​
Device: /dev/da1 [SAT], 40 Currently unreadable (pending) sectors.​
Mon, 7 Feb 2022 03:02:36 PM (Europe/Rome)
jgreco
Resident Grinch
As described in first post, the second disk doesn't appear to be online.
ZFS does not allocate files to "disks". You added the disk to the pool. ZFS now expects to be able to find this vdev, and it isn't there. This is going to be a problem. You are not going to be able to import the pool as-is.
If you have truly not written anything since adding the new disk, it is possible that there may be a way to unwind a few transactions or "zpool remove", but my suspicion is that the pool is nicely burnt toast.
There may be a possibility to import the pool with the -F switch (so zpool import -F Media_4TB) which may be able to discard the last few transactions (including the one which added the now-missing VDEV).
And ada1 was the original disk in that pool? That's bad news, but not the immediate issue. Edit: never mind; I was confusing ada1 with da1. So the question is, what is da1? If it's the new disk, that's at least part of your problem. Does the new disk show up in Storage -> Disks? If so, which pool does it say it belongs to?
...but as described in the seventh post, "Now i have connect the HD "died" from USB and the system see it." But however the system sees it, it doesn't seem to see it as a member disk of the pool in question.
My guess... da1 is likely the USB attached disk. ada1 is likely the SATA attached disk still in the pool.
That's my current guess too, but the show disks screen would tend to confirm--and would also indicate if the USB adapter was messing with it in some way (e.g., by masking a serial number).
You can see the show disk details for ada1 in the first post already. I guess the outstanding io is preventing da1 from showing up...
SuperSavio
Yes ada1 is the HDD that work.
HD that does not work I connected it via usb and now he sees it under da1 but only 1.64TB of 4TB
Yes, as expected, the USB bridge is messing with it--you can see it's also reporting an incorrect serial number. That kind of foolishness will mean that you won't be able to bring the pool online with the disk attached that way (or at least using that adapter). If you plug it back into a SATA port, will it show up now?
