I use the below script for just copies the new files and changed files and it works fine
@echo off
:: Incremental_Backup.bat Created by DA
:: It is a total copy first and then incrementally,
:: ie, it just copies the new files and changed files.
mode con cols=95 lines=5 & color 0E
Title %~nx0 for Incremental Backup with XCopy Command by DA
set "Settings=%~dp0Settings.ini"
Set "FirstFull_CopyLog=%~dp0%~n0_FirstFull_CopyLog.txt"
Set "LogFile=%~dp0%~n0_Incremental_CopyLog.txt"
If not exist "%Settings%" (
Call :BrowseForFolder "Please choose the source folder for the backup" SourceFolder
Setlocal EnableDelayedExpansion
If defined SourceFolder (
echo(
echo You chose "!SourceFolder!" as source folder
) else (
echo(
Color 0C & echo The source folder is not defined ... Exiting ......
Timeout /T 2 /nobreak>nul & exit
Call :BrowseForFolder "Please choose the target folder for the backup" TargetFolder
If defined TargetFolder (
echo(
echo You chose "!TargetFolder!" as Target folder
) else (
echo(
Color 0C & echo The Target folder is not defined ... Exiting ......
Timeout /T 3 /nobreak>nul
echo "!SourceFolder!"
echo "!TargetFolder!\Backups_%ComputerName%\"
cls & echo( & echo(
echo Please wait a while ... The Backup to "!TargetFolder!" is in progress...
Call :Backup_XCopy "!SourceFolder!" "!TargetFolder!" "!FirstFull_CopyLog!"
Timeout /T 1 /nobreak>nul
Start "" "!FirstFull_CopyLog!" & exit
) else (
for /f "delims=" %%a in ('Type "%Settings%"') do (
set /a idx+=1
set Param[!idx!]=%%a
Set "SourceFolder=!Param[1]!"
Set "TargetFolder=!Param[2]!"
echo(
echo The source Folder from Settings.ini is : !SourceFolder!
echo The Target Folder from Settings.ini is : !TargetFolder!
Timeout /T 1 /nobreak>nul & cls & echo( & echo(
echo Please wait a while ... The Backup to !TargetFolder! is in progress...
Call :Backup_XCopy !SourceFolder! !TargetFolder! !LogFile!
Start "" !LogFile! & exit
:BrowseForFolder
set "psCommand="(new-object -COM 'Shell.Application')^
.BrowseForFolder(0,'%1',0,0).self.path""
for /f "usebackq delims=" %%I in (`powershell %psCommand%`) do set "%2=%%I"
exit /b
:Backup_XCopy <Source> <Target> <LogFile>
Xcopy /c /d /e /s /i /y %1 %2 > %3 2>&1
Exit /b
this script if you like coding and scripts, also there are GUI alternatives to robocopy that can do this job without any problems or consuming much time in coding, peer sync , gs richcopy360 and securecopy quest as an example.
