Robert Shaver
- May 2, 2017
My name is Rob Shaver and I'm a retired electronics engineer who also likes to shoot and edit video. I have many hard disks from many past computers, but my working storage is two 4GB and one 5GB USB 3 external drives. I install all my apps on the 5GB boot drive but try not to put any important files on that drive. All my data goes onto the external hard drive. I also have three more external USB 3 drives for backup because I always buy them in pairs.
Because backing up is a manual operation, I don't back up as often as I should. I use Sync Toy on each drive once in awhile. I take the computer off the LAN to avoid getting a ransomware infestation while I have my backup disks connected. So this is why I'm looking for a better solution.
I have scanned through the FreeNAS docs and been reading the forums for a couple of days now. I have not found any sign of FreeNAS having a system for backing up. So that brings me to my questions (please tell me if I should post this in another forum):
Peace,
Rob:-]
- Does FreeNAS have a backup solution? (Correct me if I'm wrong but snapshots will let me recover files but are not really backups, right? If ransomware strikes I would not be able to recover the files, right?)
- Is FreeNAS Corral a likely solution? (I can't really find any documentation about what Corral is. All I find is warnings not to use it yet.)
- Is there any document that tells what Corral is in a nutshell?
- Is it possible to divide the storage installed in a single FreeNAS server into two parts, one for daily use and another for backup?
- If so, can I make the backup set off-line after each backup?
- If I can take disks off-line, can they be spun down while not in use?
- If all of this is possible, can it all be automated? (I'm pretty sure if we can do the rest, automating it won't be that hard.)
- Is there some other product I should be looking at instead?
Peace,
Rob:-]
