simonovic_peter
- May 9, 2021
I am searching for a safe and reliable backup solution. Last month I got hit by the qLocker on my main and »backup« Qnap nas. I got lucky and recovered 90% of important data (personal pictures and videos) but also lost 100% of trust in Qnap. Even more, for one of them, Qnap will terminate firmware and security updates next year. Thus, I am searching for new options and a new backup strategy (as I found out, two devices located 150Km apart are not enough if they are the same make).
What am I looking for?
The device MUST:
The device NEEDS (it is very important, but I can find another way):
If the device can (It is a »nice to have«, but not important):
My questions:
Thank you for your answers.
Best regards,
Simonovič Peter
- A device to backup my personal data. Mostly (99%) of the data, will be family pictures and videos, and some other documents. So, there will be a lot of small files.
- A 5-disk device, that will run 1 vdev mirror plus 1 »backup« disk (Formated Ext4, exFAT… so that if I do something very wrong, I can still take the disk out and get the files). The other two unused slot are for upgrading. I will buy two new disks with larger capacity and create a new pool, and then replace the third disk.
The device MUST:
- Be capable of active »bitrot« detection and correction.
- Be low power. 50W at idle without disks.
- Be low maintenance.
- To be safe to expose to the internet (port forwarding) out of the box (or with very little configuration).
- Connect to two other NAS devices one local and one remote and perform backups of certain folders.
- Run DDNS client
- Run OpenVPN server (1 occasional to a maximum of 3 concurrent connections from time to time)
- “easy” to setup, for someone who is not a professional network engineer.
- Run Transmission
- Host a gallery (like Qnaps Photostation)
My questions:
- Does Truenas CORE fit the above parameters?
- Is the following Motherboard and processor combo going to do the job?
- Will 16Gb of this ram suffice?
- It is better to use onboard sata controller or to buy a separate card?
- I have seen that for boot drives it is possible to have two usb dongles in mirror. Is this a good option or it is better to have an SSD?
- Since the device will most of the time be copying files from other NAS devices to itself over gigabit network, is it worth to invest in a larc or slog?
- I have seen, that some of you are running older i3 processors with supermicro motherboards and 1151 socket. What is your idle power usage without disks? If there is a small power increase in big performance bump, I would go that way.
- Some other suggestions?
Best regards,
Simonovič Peter
