captain stupy
- May 4, 2020
system:
ML10-V2 w/ i3 4150, 12GB RAM, 4x2TB HDD in RAIDZ2 data pool + 2x250GB SSD mirrored for Jails pool.
TL:DR:
I’m so over this seemingly endless blind trial and error I’m wondering if I should just reconfigure my NAS from scratch (minus the pools which I can just reattach) - but setup the shares and scheduled tasks and what-have-you from scratch again. Is there any downside besides time and effort to doing this that should give me pause or other considerations I should make before doing so? Are there any shortcuts?
I ran into some major problems after upgrading to TrueNAS 12.0 from FreeNAS 11.3 and trying to add a plugin.
My TrueNAS install became un-bootable and would swamp the network with unknown traffic*. I was seeing a stream of
I decided to take the opportunity while controlling for the USB flash drive boot device during troubleshooting to switch my boot device to an external USB 3 mSATA SSD.
*Durring troubleshooting I learned that my dual NICs do not behave as I assumed on the same subnet and my I wan’t manually balancing traffic by assigning jails to a specific NIC based on traffic to that jail. I have switched to LACP but whatever the overarching problem is isn't resolved so it doesn't matter yet.
TL:DR:
ipmi0: KCS: Failed to start write ipmi0: KCS: Failed to reset watchdog
on screen.I decided to take the opportunity while controlling for the USB flash drive boot device during troubleshooting to switch my boot device to an external USB 3 mSATA SSD.
- I cloned the original flash drive to it (FAILED).
- I installed TrueNAS 12.0 to it (WORKED)
- upgraded to TrueNAS 12.1 (WORKED)
- and restored the previous configuration (FAILED)
- then an fresh installed 12.0 again and restored an earlier configuration (WORKED)
- and then upgraded to TrueNAS 12.1 (FAILED immediately)
