Host: FreeNAS-11.2-U5 (Build Date: Jun 24, 2019 18:41)
Guest: Alpine Linux vanilla 4.16.53
I have come across some weirdness when adding multiple NICs to bhyve guests. Both interfaces are VLANs which are otherwise working.
Works = can ping router
First I add NIC1 and assign it to INT1
I start the guest and NIC1 works
I then add NIC2 to INT2
Now NIC1 no longer works, NIC2 works
If I then destroy the bridge for NIC2, NIC1 now works but NIC2 does not.
NIC2 on its own works fine.
The routing table in the guest is:
Which seems normal to me.
When running tcpdump initially the bridge for NIC1 shows unanswered ARP requests. After I kill the bridge for NIC2, the bridge for NIC1 shows traffic flowing as normal.
In fact while testing it seemed whenever there were two bridges one would not function. Killing the functional bridge made the non-functional bridge work. I managed to reverse the problem, NIC2 coming to life when the bridge for NIC1 was killed.
Can anyone help me understand what might be happening here?
Destination Gateway Genmask Flags MSS Window irtt Iface 0.0.0.0 10.3.2.1 0.0.0.0 UG 0 0 0 eth0 10.3.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0 172.18.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker_gwbridge 192.168.50.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
